| Servo Drives Discuss all Rutex servo drives and get direct support! |
I have r990h boards and Renco CA18 encoders http://www.renco.com/106021.htm (no longer made) but after many reincarnations the pins are starting to be faulty. I want to change them , what is Rutex recommendation on which encoders to use and not to use. Regards Paul |
US Digital encoders are good and reliable. If you get the single ended encoder, our little R2210 adapters make hook up very easy. You hook up 5 wires to the adapter and plug in a shielded cat5 cable into the drive and the adapter and you are done! CUI sells a nice little encoder for motors with 3/8 in shafts and smaller: Price is 30.00 from Digi-key corp. Part number is AMT-102v, I believe. Be sure to ask for the number for the 1 ft pigtail cable to hook to the R2210 adapter. It is dip switch selectable output between about 32 lines to 2000 or so. It comes with a set of bushings to adapt to many shaft sizes. Don't try to make your own cable. It is picky about the correct connector on it. I think the cable is just a few bucks. Tom Eldredge Rutex LLC
| Anyone got any X1 recommended feedrates... | digits | Benchtop Machines | 6 | 10-03-2006 05:54 PM |
| Recommended Laptop | hugo carradini | Mach Software (ArtSoft software) | 0 | 05-21-2006 03:49 PM |
| Recommended transformer | svon89 | Hobbycnc (Products) | 2 | 05-03-2006 09:22 AM |
| Recommended encoder? | cnc2k | Gecko Drives | 21 | 04-11-2004 07:57 PM |
| CNC recommended reading? | margni74 | General Metal Working Machines | 7 | 12-29-2003 09:28 PM |
