Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 02-09-2007, 10:31 PM
N4NV is on a distinguished road
Heidenhain encoder
I am trying to get information on an encoder. It is a Heidenhain ERO.
The encoder is marked:
ERO 120 500 F10
iDNr 220 155 10 sNr 1551729.
I looked at Heidenhein's web site with no luck. I have emailed them but they will not be open until Monday and I would like to work on them before then.
I am trying to find out the voltage, count, and current draw.
Vince
Old 04-08-2007, 04:02 AM
Don Diegoo
F.Sharifi is on a distinguished road
Dear N4NV
it must be ERO 1200 series ! - line countfrom 1024 and 2048 for ERO 125 ( TTL) and same for ERO 1285 sinsodual 1vpp .....and 1024-2048-5000 for ERO 1324 (TTL) and ERO 1348 Sin1Vpp.....Mechanical RPM 25000 rpm...supply 5 Vdc.. do you want drawing ?... let me know whats your problems ?
Old 06-17-2009, 09:36 AM
Mark Troy is on a distinguished road
Thumbs up
This thread is old, but I can add information so someone that has a similar problem can be more informed.
The Heidenhain ERO 120 is on SEM servo motors. This particular unit is a 500 line count encoder (signified by the "500" after the "ERO 120"). Outputs are far less than 1 V peak to peak. 15-17 micro according to the encoder label. Supply voltage is 5Vdc.
These are not available new from Heidenhain. You would have to contact SEM for replacement options. Of course there is a good company that repairs these routinely that can be found on the internet.
Bridgeport series 1 cnc/Heidenhein TNC 131controls boringmill Bridgeport and Hardinge Mills 3 10-09-2011 08:23 AM
5 Axis Heidenhein post processor for MasterCAMX skyline Post Processor Files 2 02-16-2007 05:20 AM
3 Axis Heidenhein post processor for MasterCAMX husseinte Post Processor Files 1 01-10-2007 09:44 AM
BP Interact 412 Heidenhein 351 besc Bridgeport and Hardinge Mills 3 10-14-2006 12:08 PM
Bridgeport Series II Interact 4 & Heidenhein Problems UKRobotics Bridgeport and Hardinge Mills 10 04-03-2006 03:27 AM
