Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 07-18-2006, 10:14 AM
zet-jaro is on a distinguished road
help dc brushless servo
ok, i got some copy-machine and i found dc servo brushless motor in there... so i want to drive it with my computer... i think that there are 11 wires... why? this is what is written on it:
DC BRUSHLESS SERVO MOTOR
FH7 - 1561 - TLO 146
DC 24V
KOKUSAN DENKI
MADE IN JAPAN
MFG. LOT NO. 2A28
and here is the picture of it http://i15.photobucket.com/albums/a3...o/DSC00057.jpg
thanks for any help
Old 07-20-2006, 12:39 PM
no one can't help me? any specification? How to drive it? I'm new in servo's so any help would be usefull
Old 07-20-2006, 01:28 PM
Al_The_Man's Avatar
There will be 2 for power 6 for encoder and 3 for hall commutation.
Which is which will be another question. There should also be another three for motor itself.
Old 07-20-2006, 01:45 PM
what is hall comunication? how accurate is this servo motor?
tnx for answers
Old 07-20-2006, 01:59 PM
Al_The_Man's Avatar
Unless someone here has the details your only hope is to try and contact the manuf.
They may be part of Sanko Denki?
Hall effect switches (or equivalent) is used to commutate the motor. the electronic version of a DC motor commutator.
Old 07-20-2006, 05:52 PM
is there any webpages with specs of servo motors?
Old 07-20-2006, 06:44 PM
Al_The_Man's Avatar
Without info, your only hope is to 'reverse engineer' it by trying to trace and identify the connections. A working knowledge of Brushless DC servo's helps.
Old 07-21-2006, 04:04 AM
NC Cams is on a distinguished road
Japanese motor manufacturers are notorious for NOT supporting aftermarket/surplus use of their motors. They consider their technology to be "know how" and not something they give away.
They also consider the motor info they gave to the OEM to be of trade secret status. Thus they protect it well. Don't expect to get much info in a reply from the motor maker anytime soon, if you get one at all.
Reverse engineer is pretty much your only hope....
Sometimes free salvaged motors are NOT worth the price you paid for them....
Old 01-06-2008, 10:57 AM
funflyri is on a distinguished road
Have u tryed going onto RCGROUPS i know that they had a lite duty 3 phase driver solution up for controlling brushless motors on small model planes with cdrom spidle drive motors.Having played with cdrom motors I can tell you the wires are as follows:
3 for the motor
2 supplying power to the hall effect's
6 return signal lines from the hall effects
You should also have extra lines coming\going to\from the encoder.
hope this helps you
Kevin
Old 02-23-2010, 02:28 PM
mindoverflow is on a distinguished road
This post comes a bit late, but maybe you're still interested.
I got the same motor and same problem, but here is my solution http://www.electro-tech-online.com/g...l-sensors.html will have it working soon.
Good luck.
Old 02-23-2010, 03:50 PM
Al_The_Man's Avatar
What drive are you using to test it?
  #12   Ban this user!
Old 02-23-2010, 05:44 PM
I'm testing it using a homemade tip and pic based driver. But i'm underpowering it, cuz i don't have a power supply big enought. the motor is rated at 24 Vdc and has 2 ohms per coil.
tschüss
