Results 1 to 6 of 6
Thread: Large DC power supplies
    Tig
    Tig is offline
    Apr 2004
    Canada BC
    I have a question regarding large DC power supplies.
    I plan on utilizing a couple of the Rutex R2020 Servo Drives (200V/40A). I wonder, is one better off to build a power supply based on a large rectified toroidal isolation transformer in the 5 KVA range, or buy an off the shelf solid state Power module such as the Servo Dynamics 4017-PM which delivers 170VDC at 40Amps continuous, and up to 80 Amps for 2 seconds. The PM also includes an internal shunt regulator. The SD 4017-PM is small 7.6 in x 5.2 in x 2.7 in., and weighing in at only 3.8 lbs. Other than size what are the advantages and disadvantages of each type of power supply. Is one inherently safer than the other? I look forward to your response.
    Thank you.
    Dec 2005
    A linear transformer (conventional or toroid) based P/S is the most rugged and inexpensive type to use/construct. A complete design analysis is found here:
    http://www.elecdesign.com/Articles/A...7635/7635.html
    As you go to single phase switchers or 3 phase inverters, you go up in degrees of complexity as well as cost as well as difficulty to construct and/or tune.
    If Bridgeport could make a CNC mill (Eztrak) that drove 3 BIG servos and do so reliably and affordably with a transformer based P/S, it would hardly seem wise to go to the trouble of using a switcher for a DIY effort - UNLESS you can get a switcher dirt cheap and can be assured it has the "oomph" needed to do what you want it to do.
    If I were building, I'd go linear - better cost vs benefit vs performance compromise.
    Edit - MUCH more robust, too.....
    Jan 2005
    Missouri
    I'm with NC Cams on this. A linear power supply whether torroidal or E-core is the most cost effective and rugged there is. K.I.S.S.
    If it's not nailed down, it's mine.
    If I can pry it loose, it's not nailed down.
    Tig
    Tig is offline
    Apr 2004
    Canada BC
    Power conditioner transformer
    Hi, is there any reason one could not use a power conditioner / noise suppression type isolation type transformer. as the bases for a DC power supply.
    I came across a: Square D, # 61605-02 Output: 120/208/240 VAC -8% to +4% , 45/26/23 Amp Max, 5 kVA Total, 57-63 Hz unit. It looks to be in good condition, and the price is right. I don't think it is a toroidal type though, is there likely to be a problem from any sort of magnetic interference, or any other problems from this type of transformer.
    Thanks.
    Dec 2005
    If it gives you the volatage and the current you want AT 100% duty cycle, sure.
    Be careful in that some such systems can't be run at full power for long periods.
    DON'T put the tranformer near a monitor as it can drive it flakey. Ditto that for ANY magnetic sensitive equipment. Transformers use magnetism to step up/down voltage and you can't effectively shield magnetic fields.
    Dec 2003
    Quote Originally Posted by Tig
    If this is a CVS type transformer, it is not a very good candidate for a power supply, they are fitted with magnetic shunts, and they have a capacitor loading a secondary winding into saturation. They run extremely hot, because of this.
    You may have to take the cover off and check the innards.
    5Kva is a fair sized power supply, you may have a problem getting a Toroid in that size, but a a square laminate type should be no problem, from Hammond.
    Unless you get it very cheap or? I would stay away from switching supplies in this range, although they will be considerably lighter
  • Posting Permissions
