| Servo Drives Discuss all Rutex servo drives and get direct support! |
Need a wiring diagram for a Electro Craft Servo. The name Reliant Electric is on the other side of the lable. P/N 0242-02-013; Model No. E242 It has eight wires. The Large Red and Black wires I know. The others are smaller with the colors; Yellow, Blue, White, Red, Green, Black Thanks |
| Depends on if it is a factory or after market encoder. If Factory colours: Red +5 Blk common White A Yellow /A Green B Blue /B With no marker pulse. If Renco it could be different but a meter or a 'scope would tell you the whole story. Al.
| The "/" means the complement of the other, you can do it with a meter but it is tricky, you have to turn the shaft as slow as you possibly can. Use a voltmeter with respect to the black -ve, you should see a alternating high and low on each line when turning slowly, the A & /A B & /B will be exactly opposite to each other, the A`s and b`s will be offset from each other. The pdf shows the marker pulse which you may not have if I am right. Al.
| The drawing of the motor in the diagram looks different than what I have. Would a picture of my motor help? Also the wiring color code on table 3, lists ORN (Orange) BRN (Brown). I have smaller gage wires Black and Red, there are no ORN or BRN colored wires. |
| There is no motor in the PDF, just the encoder, It is a Renco, Ignore the wiring details, I just used it as an example of what you will see as encoder pulses. Al.
| It depends what make, but if you look at the chart 2 in the PDF, the Renco happens to be the same wire colour as the previous one I posted for the stock encoder, if you ignore the marker or Z pulse outputs.. You can pretty much bank on red for + and Blk for -v. The rest you would have to confirm. Al.
#10
| OK. I probably should have said my electrical wiring back ground is limited to a 1965 VW Bug schematic. Without the radio option. I don't anything in the PDF marked CHART. There is a table 2 but it looks like measurements for shaft dimensions. Table 3 has wiring information but I don't see anything with MARKER or Z PULSE outputs I was looking for information to match "The CNC Cookbook" page 215, that has the Motor Drive controller diagram. It uses INC+, ENC-, Phase A, Phase B for the wires from the motor. If I understand the book? Is CH the same as Phase? ENC is a complete unknown to me. |
#11
| OK I erred. the colours are shown in Table 3. 1st page of the PDF. The signal pattern is in the lower left side of the page, the Z is shown as Index. ENC + is possibly +5v supply? CH is usually the same as phase. The main thing is to use red and black as supply and the other four are probably the A & B Pulses. Al.
| Electro-Craft Servo M1140 - specifications? | Stewey | Servo Motors and Drives | 3 | 07-13-2010 07:35 PM |
| Need Help!- Electro Craft Servo motor | sermys | Servo Motors and Drives | 0 | 04-15-2009 12:57 AM |
| Need Help!- Electro-craft servo specs for 0644? | justfx | Servo Motors and Drives | 5 | 10-05-2008 12:41 PM |
| Electro Craft BRU Servo Drives Protocol | PittsburghMick | General Electronics Discussion | 5 | 08-15-2008 11:26 AM |
| Electro-craft servo Please help | j186281 | Servo Motors and Drives | 1 | 06-15-2008 10:38 AM |
