Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Rutex Products > Servo Drives
Servo Drives Discuss all Rutex servo drives and get direct support!
Old 04-19-2005, 08:45 PM
roonster71 is on a distinguished road
power supply?????
what size power supply should i use for a rutex 990h (100v 20a max)
running 3 of these servo's without blowing my drives
and wondering if i need three power supply's or one?
Continuous Stall Torque (Oz-In) 352
Peak Torque (Oz-In) 1760
Nominal Terminal Voltage (V) 120
Nominal Operating Speed (RPM) 1750
Rotor Inertia (Oz-In-s2) 0.068
Damping Constant (Oz-In/kRPM) 1.8
Thermal Resistance (C/Watt) 1.6
Maximum Armature Temperature (C) 155
Maximum Friction Torque (Oz-In) 8.0
Terminal Resistance, Nominal (Ohms) 4.3
Weight (lbs) 8.0
Torque Constant, kt (lb-In/Amp) 5.5
Back EMF Constant, ke (V/kRPM) 62
Maximum Continuous Current (A) 4.0
Maximum Peak Current (A) 20.0
thanks in advance
Old 04-19-2005, 10:22 PM
ViperTX is on a distinguished road
Yikes, check with Rutex....I'm worried about your Back EMF rating....for short durations at max rpm it will exceed the voltage rating of the FETs. I don't know if Rutex has a maximum temp. cutoff to protect the driver.
And if you're planning on running at the Terminal Voltage...you got more problems.
Old 04-19-2005, 10:50 PM
I'm not planning to run at full voltage people say these run fine on a geko with 80vdc
of couse you never know till you try it...... this is the first time ive ever used a servo untill now ive only run a stepper controller 24v 2a xylotex on a sherline mill that ive out grown maybe i should have got the servo first then the drive??? (chicken before the egg )
Old 04-25-2005, 03:57 PM
rutexus is on a distinguished road
Roonster,
I have been away for a couple of days with my boys on an international robotics meet. Back now to offer usual support.
I run very similar motors on the R990H with no troubles. I run them at 85 Vdc. This gives me a margin for different customer's line voltages. My motor terminal voltage is 140 vdc.
I use an 8 amp power supply for two axis. I think you would do fine with 12 amp.
Amveco, in Texas is my latest supplier. I pay 85.00 for a 10 amp transformer plus shipping.
I would use one common power supply for all axis (The 12 amp one). You will need the transformer, a bridge rectifier, and around 22,000 of filter caps, rated at at least 100 working vdc. Keep the filter caps within 18'' of the drive.
I have also configured a similar motor, with 26 inch lbs of torque with the R990H drives. With a 1 ohm load resistor in series with the motor, I measure 18 volts over the resistor at the instant that the motor stops. At this point the drive is turned off, and what I am seeing is the BEMF. In other words, at that point the motor is acting as a generator, and it is generating 18 amps of current (18 volts/1 ohm= 18 amps). I leave the resistor in the motor circuit, and also fuse it.
We do not notice any decrease in performance as a result of the resistor, believe it or not, and it does allow me to use a motor that is priced well, and normally in stock at Servo Dynamics.
I hope this helps.
Tom Eldredge
Old 05-04-2005, 02:20 AM
Originally Posted by rutexus
Roonster,
I hope this helps.
Tom Eldredge
What should the ac voltage out be on the tranformer (secondary?) to make 85vdc 12amp after bridge rectifier and cap????
thanks
Old 05-04-2005, 02:55 AM
2muchstuff is on a distinguished road
Coming out of the transformer you should have 60 volts AC, (85 / 1.414= 60).
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 05-04-2005, 01:07 PM
Yes, the 60 volts DC is correct. Transformers are rated at a certain amperage. If you underload them, the voltage will be slightly higher than their specified rating, but not too much higher. I use a 59 VDC, 10 amp transformer at 125 vac and get 85 vdc. 60 vdc is fine.
Tom Eldredge
Rutex LLC
Old 05-04-2005, 08:00 PM
Roonster,
I hope this helps.
Tom Eldredge
do you have the part number for the Amveco 10 amp transformer???
thanks
Old 05-05-2005, 08:18 PM
Amveco transformers
The part number for the AMVECO transformer:
10.8 amps, 60 volts: AA5650-2030 $82.00 (typically for 2 axis of 22 inch lb motor)
13.2 amps, 60 volts: AA5790-2030 $84.00
16.7 amps, 60 volts: AA5000-2030 $98.00
They might also have some small "copper charges" like $3.00-$5.00
I realized after I got these part numbers, that AMVECO will only sell to oems and resellers.
If anyone wants me to order one for them, I'll mark it up 13% and have it drop shipped to you. I won't say I'll always do this, but I'm willing to try it.
I'll also charge modestly for the shipping.
The 13% will cover my credit card fees and administrative costs.
Tom Eldredge,
Rutex LLC
Old 05-06-2005, 09:33 AM
Gold Member
lerman is on a distinguished road
www.avellindberg.com has toroid transformers for excellent prices.
My 1200VA toroid transformer was about $80.
(If you talk to Melanie, tell her Ken from Newtown recommended them.)
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
  #11   Ban this user!
Old 05-09-2005, 08:55 PM
Toroidal transformer lead
Thank you for the lead. It looks like a good one. I'll check it out!
Tom Eldredge
Rutex, LLC
  #12   Ban this user!
Old 06-10-2005, 01:01 AM
Unhappy transformer trouble?
hi all thanks so much for the help
i order a power supply kit so every thing would come out right (i thought) well any way i got a transformer and a cap and bridge rectifier and theristor and bleed resistor but i get 70vac out of the transformer and i messure 97~100vdc at the capacitor with no load on it. is this normal and will this work? should it be mesured under a load? i dont want to fry my drives!!!
thanks
roonster
How does a power supply work. ynneb DIY-CNC Router Table Machines 1 07-27-2011 10:40 AM
Diy Power Supply Choices berin DIY-CNC Router Table Machines 11 07-13-2005 04:47 PM
5 Volt Power Supply Tripping murphy625 General Electronics Discussion 13 02-27-2005 10:05 PM
Is this power supply rating adequate? jerryrigge General Electronics Discussion 3 11-25-2004 11:06 AM
Choosing a Power Supply for Retrofit? pfeist General Metal Working Machines 4 05-23-2004 11:36 PM
