Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
Results 1 to 7 of 7
Thread: Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
    Jan 2017
    United Arab Emirates
    Default Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
    Hi there
    I am trying to run a Delta 750 W servo motor, and delta ASDA-B2 Driver
    I wired every thing and I get the AL.013 Code in the driver LED Display, apparently is the right Code,and it shows that my wiring are correct. But this is as far as I
    could go, I simply have not been able to Run the Motor as of yet. Any recommendation is greatly appreciated. I think I must turn off the emergency or brake Code.
    but the User manual is simply vague.
    By the way my Controller is Mach3 Motion CARD ESS(Ethernet Smooth Stepper) HM-LAN-4Axis.
    regards
    jhonansaro
    Member Iron-Man's Avatar
    Jan 2009
    Default Re: Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues
    Quote Originally Posted by johnansaro View Post
    Hi there I am trying to run a Delta 750 W servo motor, and delta ASDA-B2 Driver I wired every thing and I get the AL.013 Code in the driver LED Display, apparently is the right Code,and it shows that my wiring are correct. But this is as far as I could go, I simply have not been able to Run the Motor as of yet. Any recommendation is greatly appreciated. I think I must turn off the emergency or brake Code. but the User manual is simply vague. By the way my Controller is Mach3 Motion CARD ESS(Ethernet Smooth Stepper) HM-LAN-4Axis. regards jhonansaro
    Please check if any of the digital input DI1~DI8 is set to emergency stop (EMGS). See attached pdf of manual, top section. Hope this helps, Iron-Man
    Attached Thumbnails Attached Thumbnails Delta Servo Motor 750 W and Delta ASDA-B2 drive setup issues-delta_ia-asda_error-al013-pdf
    Jan 2017
    Hi there
    Does anybody have the List of parameters for the Delta ASDA-B2 driver with 750 W Motor? if you do, could you please provide the List.
    Regards
    jhonansaro
    Jan 2017
    Default Issues on setting the moving direction of delta asda b2 servo motors/drivers
    Hi there
    How can I change or set the direction of moving my Delta asda b2 servo motor/drivers?
    What is the parameter that i need to change, in order to change Cw, or CCw direction of my motor?
    I searched the net, but It is very hard to get information on servo motors.
    Regards
    jhonansaro
    Jan 2017
    Default Delta adas b2 Software
    Hi there
    During the auto gain Tuning, my value of Inertia Ratio, which should be around value of 4, is a low value of .1 (off course after tuning process )
    What could cause that?
    What is exactly Inertia Ratio?
    regards
    jhonansaro
    Jan 2017
    Default Re: Issues on setting the moving direction of delta asda b2 servo motors/drivers
    Solved no need to reply
  7. #7
    Jan 2009
    Great to see you get it running. When you have your parameters set, go through all of them and write them down on paper. Post pictures. Iron-Man
