Need Help! 4th Axis Servo motor Oscilate when idle
Results 1 to 5 of 5
Thread: 4th Axis Servo motor Oscilate when idle
    Feb 2017
    Austria
    Default 4th Axis Servo motor Oscilate when idle
    Hi guyz,
    we are building 4h axis for CNC milling mashine. Everything was ok until we made a decision to switch to servo (from stepper). The reason was the idea to get high speed and to use 4th axis as lathe...
    Hardware:
    Servo motor is original Chineese servo
    https://www.aliexpress.com/item/Serv...ceBeautifyAB=2
    The problem is that the driver does not have USB connection so we can not adjust parameters using any software. Its done by UP, DOWN, ENTER, BACK on the panel....
    You can see the problem in the following video:
    https://drive.google.com/open?id=128...QZJiMI3cmJ7UjN
    We need to have the motor withuot oscilation but we have no idea how to set all those PID parameters.
    Here is also PDF with all parameters of the servo driver:
    https://www.machsupport.com/forum/in...0;attach=44811
    Any help is welcome!
    Thanking you all in advice!
    Member CoAMarcus's Avatar
    Jan 2007
    Default Re: 4th Axis Servo motor Oscilate when idle
    Does the problem happen only when you push that block by hand? Is the motor stable normally until it is pushed out of position?
    This looks like it is going to be a combination of two things: A misadjusted PID loop and too high of a gain setting on the PID loop. What is your encoder line count?
    Marcus Freimanis
    www.geckodrive.com
    Member awerby's Avatar
    Apr 2004
    If you're using a normal rotary table with planetary gearing, there's no way it's going to go fast enough to operate as a lathe. You'll just destroy your rotary table by trying to do that. If you really want to make your milling machine into a combination mill/lathe, adapt a lathe head to the bed and power it with a regular motor - it doesn't have to be a servo - using a pulley cluster to get various speeds. If you want to be able to mill on the turned parts, work out a way to fix it firmly in position while you do that - or swap the rotary table back onto it, with its restored stepper motor.
    Feb 2017
    Austria
    Quote Originally Posted by CoAMarcus View Post
    This happens only when I try to rotate the shaft. When I stop it, it stays idle (does not start to move from itself).
    I dont know where to find the information for encoder line count. It has some kind of electronics gear (3 parameters) to set units per...
    Feb 2017
    Austria
    Quote Originally Posted by awerby View Post
    Lets say that it should work as combo, so both of your ideas wont work...
