Newbie Lets talk about encoders - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
Thread: Lets talk about encoders
  1. #21
    Member CS900's Avatar
    Aug 2006
    Default Re: Lets talk about encoders
    ok, so since the magnetic encoder also has a A and B phase I should also multiply the 1016 by 4, correct? Giving a value of 4064 to enter into the firmware.
    Also, thanks for the help everyone. I'm pretty green when it comes to the details of motion control.
  2. #22
    Dec 2013
    Quote Originally Posted by CS900 View Post
    No, enter 1016, that is the ''lines'' multiplied by 4. In this case, the lines = 254.
    Jim Dawson
    Sandy, Oregon, USA
  3. #23
    Aug 2006
    ok, so being overly anxious to get my mill up and running again I spent my lunch break working on this.
    Jim, thank you very much for your help. It seems to be working great at 1016.
    I hope I'm not beating a dead horse here, but how to you figure the 254 lines? I calculated 1016 given the pitch of the screw and the resolution of the encoder. Does the tape have 1/4 less "lines" than I think it does?
    Lets see if this works:
    https://www.instagram.com/p/Be0xdQ_j2Ow
  4. #24
    Dec 2013
    254 lines is 1016 / 4
    The linear encoder does not really have ''lines'', but the that would be the rotary encoder equivalent. The tape actually has 2mm magnetic pole spacing and the internal read head electronics converts the sin/cos output to pulses that the encoder input can read. It's all done with electrical magic
    Jim Dawson
    Sandy, Oregon, USA
  5. #25
    Aug 2006
    well when it comes to electrical magic, I just dont ask why anymore. Thanks again for the help!
  6. #26
    Dec 2003
    The only scales that are the same are the optical scales, they are identical in design to the rotary version, except linear in construction.
    Aug 2006
    well I may have done my victory dance prematurely. I went to start tuning mach3 today and the motor was very jumpy and eventually faulted out. I reset the drive went back to the tuning software and tried running the same exact test as the one in the video and I'm now getting around a 750 pulse error and I can hear the stepper making a funny noise. I checked the coupling connecting the motor and ballscrew to ensure it was not slipping and it's not. I also reconnected the original encoder and changed the encoder count back to original and it works fine again.
    My next though was maybe the tape wasn't aligned to the sensor since I had jogged the machine down maybe an inch. So I disconnected the ballscrew from the saddle and ran the saddle up and down the entire travel and the green "go" light stays on the entire time.
    Any idea what I could look at to start troubleshooting?
  8. #28
    Dec 2013
    Try setting the acceleration/deceleration in the drive to something crazy high. Then lower the acceleration in Mach3 to a very low level to start with. Mach3 controls the acceleration, I suspect the drive and Mach3 are having a bit of a battle internally.
    Jim Dawson
    Sandy, Oregon, USA
  9. #29
    Aug 2006
    I'll absolutely do that, but the issue now being that the protune software is the one sending the control signals for the test. Mach3 isn't even running at the moment. I'm a little baffled as to what changed as the only thing that differs between now and yesterday is the fact that I tried to use mach3 in between.
  10. #30
    Dec 2003
    Just to give you an idea, industrial versions of CNC equipment that implement scales have a dual loop, One encoder on the motor, the other the linear scale on the axis, this due to problems that can arise when there is any excessive or noticeable backlash between motor and final motion.
    Galil have a video explaining how a PID loop is tuned when implementing this arrangement and there is backlash present, the PID loop tuning is spread between the encoder and the scale.
    Aug 2006
    that was my first thought as well, which lead me to check the coupler. I know that the ballnut has less than .001" of backlash from previous measurements. Also, I'm not sure why this wouldn't have been an issue yesterday if it were excessive backlash.
  12. #32
    Aug 2006
    So I played around with it a bit last night and I have a theory for you guys to scrutinize. The encoder seems to work fine over short distances...sometimes....If i plug in the original encoder and jog the machine to a new position sometimes it works, sometimes it doesn't. Sometimes it will work for a certain distance and then bugger up. I'm wondering if the tape has reference marks (like the picture) and i have the tape installed backwards and when it gets to a reference mark it buggers everything up. I don't have a good way to solidly mount the encoder flipped so before I go make a bracket I wanted to see if this was a viable problem. for what it's worth, I don't see any reference marks on the scale.
    Lets talk about encoders-encoder-jpg
  13. #33
    Dec 2003
    The reference or fiduciary marker is usually separate to the main encoder outputs, so it should not affect it, at least on the scales I have used.
    Aug 2006
    I guess I'm wondering if the A or B sensors are reading that line when they shouldn't be?
  15. #35
    Dec 2003
    Not if the system used to track the head to tape is in order. and kept aligned.
    Registered James Newton's Avatar
    May 2005
    Quote Originally Posted by Al_The_Man View Post
    This is really interesting Al. I went looking and couldn't seem to find that video, any idea what keywords I should use? Or if you have any other info on it, I'd love to hear.
    Are they doing an /inside/ PID loop between the motor and the encoder, and an /outside/ PID loop between that loops setpoint and the scale? Or something else?
    James hosts the single best wiki page about motors for CNC hobbyists on the net:
    http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
  17. #37
    Dec 2003
    I will see if I can find it, the PI uses the motor and the scale the D IIRC.
    Looks like it is the last video under Tuning.
    Online Videos | Galil
    You have to register to view them.
    May 2005
    Argh. I hate that. But with the title of the video in hand, a little google-fu brings us to:
    Two Feedback Loops are Better Than One | Machine Design
    and I've used that to update my page at:
    techref.massmind.org/techref/io/servo/index.htm
    Turns out it's PD inside and I outside.
  19. #39
    Dec 2003
    Quote Originally Posted by James Newton View Post
    And of course, Jacob Tal is the president of Galil!
