hi jim,
it lives, it moves!!!! yeah!
the problem was a faulty cable from my power supply. i connected pin 3 and 5 to comm, left pin 4 the standby pin alone, is that okay? 0-10v is on pin 11 and 12.
so the next thing is to connect pin 3 and 5 and comm to the spindle relay on the bob. pin 11 and 12 to the 0-10v output on the bob and one cable from the yet to build spindle index to an input pin from the bob. that should be the electrical setup, right?
for the transducer: i guess that thing gives the signal to switch poles inside the servo controller and therefore its positioning is important. could i just take an handheld rpm meter, measure the rpm and after that turn the transducer a little bit and measure rpm again. if it gets faster ( same input voltage) the transducer should have a better position?
thank you so much for your help,
michael
