Need Help! Sanyo Denki servo drive and Mach 3 config
Results 1 to 13 of 13
Thread: Sanyo Denki servo drive and Mach 3 config
    Mar 2005
    Default Sanyo Denki servo drive and Mach 3 config
    Hi everyone,
    i need your help with the config.
    I have a sanyo denki 65B015DDK01 model and i'm trying to make it run with Mach 3. My breackout board is a +5VDC step/dir from china. (it work with my gecko drive)
    manual pdf http://www.sanyodenki.biz/products/I...28PY2%29-E.pdf
    i've try to follow this thread
    https://www.machsupport.com/forum/in...&topic=2303.10
    Re: Sanyo Denki BL Super servos
    « Reply #15 on: May 19, 2007, 10:01:20 AM »
    Pin 1-2-3-4 on Cn1 1 and 3 beeing step and dir and 2-4 beeing ground
    Dont have the paralellport diagram in front of me, so i can not tell you right now if 1 or 3 is step and the other one dir.,but ill see if i can find it
    --end quote
    but nothing moves. there is power on the motor but when i try to send the inpluse nothing happen and if i turn the motor by hand (really hard) then it return to the original position where it was before i turn it.
    i\ve also try to copy this guy setting but i get the same results.
    Sanyo Denki servo drive and Mach 3 config-20171112_172103-1-jpgSanyo Denki servo drive and Mach 3 config-20171112_172103-1-jpgSanyo Denki servo drive and Mach 3 config-20171112_172210-1-jpg
    Member jalessi's Avatar
    Feb 2007
    Default Re: Sanyo Denki servo drive and Mach 3 config
    k-linkz,
    In your posted image you do not have a EStop switch or jumper connected to the breakout board, are you sure the breakout is outputting step and direction pluses?
    It also appears as if you are using only two wires for step and direction, what about the common wire?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2005
    hi Jeff,
    thanks for the reply,
    In your posted image you do not have a EStop switch or jumper connected to the breakout board, are you sure the breakout is outputting step and direction pluses? did the bypass with the jumper cable
    It also appears as if you are using only two wires for step and direction, what about the common wire? it there it's just black. (there are 3 wires) the enable wire is not tap into anything.
    i've try with the e-stop in bypass physically (just a wire to bypass) and try to bring the common to pin 3-4 on the sanyo denki drive.
    still the same results = motor stay strong in the same position (hard to move) and when try to move comes back position 0.
    . i'm woundering if maybe the sanyo drive needs something special to get into position mode but i didn't find any pin to play with
    Mar 2005
    if i plugin the gecko drive all the axes x y z (i'm able to move the axes) , but with the sanyo denki it just stays there hard and won't move and if i try hard to move it (by hand ) it comes back to the original position.
    Feb 2007
    Do you have the Remote Operator? It is required to configure the drive for Position Mode.
    Feb 2007
    See attached image:
    Attached Thumbnails Attached Thumbnails Sanyo Denki servo drive and Mach 3 config-position-jpg
  7. #7
    Mar 2005
    Thanks jalessi,
    Quote Originally Posted by jalessi View Post
    See attached image:
    humm.. not sure we have the Remote Operator... gonna have to check and see if it was ship with it. Do you think this is related to configure the drive for Position Mode.
    it's not clear to me how torque - position - velocity mode - could after enabling/disabling step- dir pins on the drive. But maybe there is an option with Remote Operator that can enable and disable remote step - dir.
  8. #8
    Mar 2005
    looking at the drive model 65BA015DDK01 i'm not sure it had a Remote Operator pad,
    I not so sure this model even has an Remote Operator pad...
    where would one plug the pad ?
    Sanyo Denki servo drive and Mach 3 config-drive1-jpg
    Sanyo Denki servo drive and Mach 3 config-drive2-jpg
    Sanyo Denki servo drive and Mach 3 config-drive3-jpg
    Sanyo Denki servo drive and Mach 3 config-drive4-jpg
  9. #9
    Feb 2007
    Angry Re: Sanyo Denki servo drive and Mach 3 config
    We need the correct manual!
  10. #10
    Mar 2005
    i agreed, manage to find the data sheet 65BA015DDK01
    manage to find this on the web:
    https://www.google.ca/url?sa=t&rct=j...s0m6ezvlouRP30
  11. #11
    Feb 2007
    You must find the CORRECT documentation.
    I am willing to bet the amplifiers you are in possession of do NOT SUPPORT Position - Step / Direction!
  12. #12
    Feb 2007
    Ask "Al The Man" to chime in, he has been around since the dinosaurs and may have helpful relevant information.
  13. #13
    Mar 2005
    Thanks jalessi for the inputs.
    note to myself for tomorrow or next week cuz i'm tired and before i lose the idea:
    sanyo denki drive :
    seems to be 1 and 2 (for step and dir) pin 3-4 nothing pin 5-6 switch enalbe/disable something and pin 27 - 21 jump wire
    from source time 0:11 :
    mach3 config :
    also put kernel at 1mhz or whatever high it is 100khz cuz it seem the 25khz standard might too low
    Breakoutboard 5axis in line:
    need 5VDC at bottom for output or usb plug at the top and if use input at side 12-24vdc on the side
    Breakoutboard 4axis in line 1axis on the side:
    different setup then the one above. check config again
    Exhausted brain say: if it work before then there most be away to work again
    try
    This ac servo drive should takes step and direction signals. +5vdc to +sign and +pulse. step signal to (- sign), direction signal to (-pulse).
    there most be a away the youtube guy make it work with just 5 wires and 1 of them is a jumping wire.
    buy coffee from Tims tomorrow you earn it.
    P.S. check e-stop config again.
    P.S.S. work after coffee try to not burn down the shop or get electrocuted.
