Need Help! Yaskawa SGD-04- VH
Results 1 to 8 of 8
Thread: Yaskawa SGD-04- VH
    Nov 2017
    Italy
    Unhappy Yaskawa SGD-04- VH
    Hi all guys,I'm new to this forum,
    after asking the yaskawa without any answer, and after weeks of research, ask you if anyone knows this servo drive model or if it has the right manual to know how to connect to the programming and a pin-out scheme. Thanks in advance
    Attached Thumbnails Attached Thumbnails Yaskawa SGD-04- VH-img_7759-jpg
    Member mactec54's Avatar
    Jan 2005
    Default Re: Yaskawa SGD-04- VH
    Quote Originally Posted by andreatomaghell View Post
    The basic wiring is the same as any model, the difference with yours is, The ( H ) is for serial communication, and position control
    Here is a PDF for that drive, do you have the matching 400W motors
    Attached Thumbnails Attached Thumbnails Yaskawa SGD-04- VH-sgd-04-h-manual-pdf
    Mactec54
    Nov 2017
    Italy
    Thanks so much mactec54!now I will try to connect with the Sigma Win program,
    to make sure they work ..
    the idea is to run them with Linux cnc, and heidenhain optical scale with sin / cos to TTL converter ... the dialogue between linuxcnc and sgd servodrive will be on CN1?
    Nov 2017
    Italy
    Goodmorning everyone!
    I'm still in trouble with this servopack !!
    after many tests I still can not access the parameters ...
    I tried different links with rs232 I tried with an rs422 interface, I tried with SVMON version 2-1 r3 and 35r4 .Sigmawin plus ... I do not know what to do anymore, I always get the answer that the servopack is not found.
    And I've tried with both drives I have available .. nothing. what I do? I throw them away? Connector CN1 and CN2 are
    disconnected.
    Jan 2005
    disconnected.
    SVMON should work, sigmawin will not, your cables also have to be correct, a lot have had problems with cables not having the correct wiring configuration
    Mactec54
    Nov 2017
    Italy
    I will not stop trying but I ended up with the idea, my last http://www.cnczone.com/forums/attach...d=378784&stc=1
    Attached Thumbnails Attached Thumbnails Yaskawa SGD-04- VH-schermata-2017-11-15-alle-17-03-a
  7. #7
    Nov 2017
    Italy
    Hello!
    please can you tell me how you set wire for connection?
    thank you!
  8. #8
    Jan 2005
    Hello!
    thank you!
    I have never made one of these cables, but some have made them, I have always used the Yaskawa made cables
    Mactec54
Yaskawa SGD-04- VH
Yaskawa SGD-04- VH
