Need Help! Encoder wiring
Results 1 to 6 of 6
Thread: Encoder wiring
    Registered dhc2beaver's Avatar
    Sep 2017
    Default Encoder wiring
    Hello all
    I am new to the CNC world and thought, what a better place to learn.
    I recently purchased an older Techno/Isel CNC router table and am upgrading all the electronics.
    I am building a new control box with 3 Gecko G320x drivers and a PMDX-126 break out board.
    The table has Techno/Isel servo motors with DRC TK731 8E21 500-B encoders.
    My problem is that I cant find any specs online showing what wire is what to connect the above encoders to the new Gecko drives.
    I have found some data sheets online for other DRC encoders showing the wire info and they all seem to have the same colour codes, but am a little leary to just wing it.
    So I thought I would use all of your experiences.
    Any help would be much appreciated.
    Cheers
    Wayne
    Attached Thumbnails Attached Thumbnails Encoder wiring-img_1854-jpg   Encoder wiring-img_1855-jpg
    *Registered User* SAMI81's Avatar
    Oct 2018
    Default Re: Encoder wiring
    Quote Originally Posted by dhc2beaver View Post
    Hello all
    Cheers
    Wayne
    Any luck with this? I seemed to have the same issue, don't know how to connect the encoder to gecko!
    Member Iron-Man's Avatar
    Jan 2009
    Hello all
    Cheers
    Wayne
    Hello Wayne
    Try this, it should point you in the right direction.
    Hope this helps,
    Iron-Man
    Member zimbrich's Avatar
    Jul 2021
    Quote Originally Posted by Iron-Man View Post
    Hello Wayne
    Hope this helps,
    Iron-Man
    This is very good information, but is only for mechanical installation. I am looking for the wiring diagram for the same encoder. Unfortunately, DRC was bought out and then the parent company got bought out. So it looks like there is no information on this encoder on the Internet. Do you happen to know where any old DRC documentation might have landed?
    Thanks!
    Member machinehop5's Avatar
    Aug 2009
    Quote Originally Posted by zimbrich View Post
    Thanks!
    ...I would be guessing but, I'll bet the color Code is the same on other DRC encoders. For example found this pdf for a TK91
    Attached Files Attached Files
    Jan 2018
    United Kingdom
    Thanks!
    This has DRC stuff in it. Not sure if it's right but worth a browse through.
    http://irtfweb.ifa.hawaii.edu/~tcs3/...der_primer.pdf
Encoder wiring
Encoder wiring
