Need Help! Muirhead servomotor
Results 1 to 4 of 4
Thread: Muirhead servomotor
    Aug 2017
    Israel
    Default Muirhead servomotor
    Hello,
    I currently using by t Muirhead Geared shaft Servo Motor model 18M10B4 (mfg date 6-82) , 115V Size 18 (See attached images for your reference )
    Gear part of the motor become worn over time , doesn’t work properly and need to be replaced with new.
    This motor is a part of lift up/down system of old Electrical discharge machine.
    Since it was manufactured in 1982 can't get any response fro Muirhead (currently Ametek) company.
    Any one can help with two options :
    1) Where to buy exactly the same form and function motor.
    2) It is possible to repair / replace the gear shaft. (please advice the company who can do that)
    Thanks in advance
    Thank You and BestRegards,Vitali
    Attached Thumbnails Attached Thumbnails Muirhead servomotor-motor-images-pdf
    Dec 2003
    Default Re: Muirhead servomotor
    What does it presently drive? A small gear box?
    What is the technology of the motor, it does not appear to be a brushed motor, is it a stepper?
    You say 115v? It wouldn't be a small AC synchronous motor by any chance?
    I see 60Hz on one motor!
    Have you tried ebay? there is a few on there.
    Aug 2017
    Israel
    Default Re: Muirhead servomotor model 18M10B4
    Quote Originally Posted by Al_The_Man View Post
    Hello ,
    It drive gear box consist of 3 more gears
    Motor technology: Continuously rotated 115V AC gear shaft six wires Servo Motor
    I did try in ebay but i cant find exactly the same or similar models .
    Regards,Vitali
    Dec 2003
    In spite of 6 wires It does not appear to be a stepper at 150v, possibly BLDC with 3 stator wires and three commutation sensors.
    If you have the schematics on the machine you may have to find and integrate a replacement, what is the make of the machine itself?
Muirhead servomotor
Muirhead servomotor
