Step direction signal converted to CW-,CW+, CCW-, CCW+
Ok, so I'm rebuilding my 3d printer and I've come across a compatability issue. My controller has step/dir output pins. The drives have the CW-,CW+, CCW-, CCW+ inputs.
I haven't been able to get this to work correctly.
First I tried,
cw- and ccw- together going to ground
cw+ to step signal
ccw+ to direction signal
On controller connector I have
Pin1 = step
Pin3 = direction
Pin2 and pin4 ground to pin 18
Like this the motor runs quickly one direction but very slowly the other direction.
It also travels less in the slow direction.
I undid all that.
Then I,
Set Parameter 4 to 1
I have a DC DC converter going from 24vdc to 5vdc. The positive side of 5vdc output runs to CW+ and CCW+ (pins 1 & 3)
The step signal is run to CW- (pin 2)
The direction signal is run to CCW- (pin 4)
The motor runs one direction until it crashes. No matter how far I tell it to go. Nothing happens in the other direction.
So I'm at a loss. Pleeeeease help.
If I'm understanding it correctly some people have used some sort of logic gate based circuit. Unfortunately for now, that's just over my head.
The board is a azteeg x5 gt
The drives are stonker (China)
It will be easier to find the later 74HCT00 than the original 7400 that dates from the 1960's
just make sure you get the 14- PDIP version
(= plastic 14 pin package with pins that fit the 0.1" grid found on vero / perf board
its easier to start with than the 14-TSSOP used on surface mount PCB's )
Re: Step direction signal converted to CW-,CW+, CCW-, CCW+
Ok so is there any reason why the nte7426 ic would not work? I attached the info.
I also attached a sketch of how I wired it. It is mirrored to make it easier on me.
With it done this way the motor constantly rotates clockwise. If I jog + it continues to rotate. If I jog - it still rotates clockwise but slower. Any ideas?
Not sure if this matters but I'm using a dc-dc converter to go from 24vdc to 5vdc and then pulling ground and +5vdc from there. Also motor is spinning on its own on system power up before the controller board is connected.
If I remove the connection from from the drive nothing happens connected or not connected to controller.
With +5vdc connected to CW+ and not connected to CCW+ nothing happens and same for vice versa.
only just read your post ,
its taken a while to un-install the last windows up date and then have a go re-installing them
you know how it goes when it installs too many at once
the capacitors don't need to be exactly the values in the diagram
the electrolytic can be 100uF to 470 uF , 10V to 25 V what is easiest to find
the usual practice is to connect a 0.1 uF 50V ceramin capacitor across the 5V supply to every 1 or 2 TTL IC's
placing the capacitor close as practical to the supply pins
