Dear friends
i have a INTERMAC 1500 glass 4 axis router.The machine is using a OSAI 10 controller and the motors and the drivers are the bru 500 and the bru 200 from Reliance Electric
I try to retrofit the machine and intend to use linux cnc and mesa analog card .I have problem with the motors When i enable the motors they are rotate with stable small velocity CCW
I don't believe that i can tune them because in the user manual of the driver https://www.axcontrol.com/pdfs/bru-500.pdf for communicate with the motors a certain program called ECC PROG is needed and i can not find it
if anyone have any suggestion for this problem
thanks
Yannis
