Help with the choice of servo drive for servomotor
Results 1 to 5 of 5
Thread: Help with the choice of servo drive for servomotor
    Mar 2017
    Question Help with the choice of servo drive for servomotor
    Hi all.
    I use small router with stepper motors.
    But a few servos without servodrive got into my hands.
    Link on the manufacturer's website and servo model https://www.br-automation.com/en-us/...25r0060d000-3/
    I can use another driver for this motor, not the original one?
    Maybe some cheap used yaskawa drive from ebay can work with this servomotors?
    Jun 2005
    Default Re: Help with the choice of servo drive for servomotor
    sigsig,
    Servo Motors are typically matched to Servo driver with those exact requirements. A Yaskawa driver wants to see a servo motor at the right voltage and right encoder. This is true of most name brands like Panasonic, Fanuc, Mitubushi, etc. The driver electronics will sense if the right encoder is attached and the motor needs to be the right voltage or you can burn out the motor and driver. If you get a 240V driver you need to find the matching 240V servo. You can not mix the 120V driver and the 240V servo or vise-versa. You can download the manuals on the various servo drivers and they will tell you exactly which servo motor needs to be used.
    If you go with BR Automation then use their designated driver.
    Russ
    Dec 2003
    That shows a synchronous (AC) motor with a resolver F.B. so matching a drive I could see no easy matter, They can be converted to BLDC but a encoder with commutation tracks would be needed.
    Member mike_Kilroy's Avatar
    Sep 2010
    Why not the matching b+r drive? Spec says resolver is 2 pins?
    Sent from my SM-G900V using Tapatalk
    Mike@@@KilroyWasHere.com
    Registered James Newton's Avatar
    May 2005
    If you can find a way to drive the motor from PWM / direction signals, my generic servo driver can work.
    James hosts the single best wiki page about motors for CNC hobbyists on the net:
    http://techref.massmind.org/techref/io/motors.htm Disagree? Tell him what's missing! ,o)
