Analog drives for DC motors that run encoders? - Page 4
Page 4 of 4 FirstFirst 1234
Results 61 to 74 of 74
Thread: Analog drives for DC motors that run encoders?
  1. #61
    Nov 2016
    Default Re: Analog drives for DC motors that run encoders?
    Quote Originally Posted by Jim Dawson View Post
    Cool! I'm working on getting the CNC software prepped for install. I have never actually done an installation on a new computer. My neighbor has a ''clean'' computer I'm going to try to install it on, everything I have has the development software on it.
    Great! Sounds like gears are turning!
    I am going to wait a little bit on the Phoenix contact. eBay and Amazon sell it, but it is about $155 and both are in new condition.
  2. #62
    Dec 2013
    It's time to start thinking about wiring so attached is a manual for your servo drives.
    Attached Thumbnails Attached Thumbnails Analog drives for DC motors that run encoders?-fenner-drives-pdf
  3. #63
    Nov 2016
    Analog drives for DC motors that run encoders?-galil-1830-jpgAnalog drives for DC motors that run encoders?-galil-1830-installed-jpg
    The Galil 1830 came in today.
  4. #64
    Dec 2013
    Looking Good!
  5. #65
    Dec 2003
    I was just sorry to see the IDC edge connector used on the older legacy boards go in favour of the odd ball one used now.
    It made it so much easier to interface.
    Nov 2016
    It was probably a whole lot cheaper too.
  7. #67
    Dec 2013
    I really don't like the new D-sub format, all of the cables take up too much panel real estate. I'm kinda partial to the old 80 and 100 pin format. Much more compact.
    this:
    http://www.cnczone.com/forums/attach...d=349098&stc=1
    vs. this
    http://www.cnczone.com/forums/attach...d=349100&stc=1
    Attached Thumbnails Attached Thumbnails Analog drives for DC motors that run encoders?-img_0095-jpg   Analog drives for DC motors that run encoders?-img_0103-jpg
  8. #68
    Nov 2016
    this:
    vs. this
    Is there a difference between one 100 pin connector and another? I am looking at some options for buying them and I am noticing that one kind has a plug that looks more square, while another type has a more rounded plug appearance. Both are said to be 100 pin cables. Would buying one or the other make any difference? I don't know if they are product specific.
  9. #69
    Dec 2013
    The only ones that I have seen are shaped like any D-sub cable connector, or more like a SCSI connector. Look at the connector on the Galil card, it should mate to that.
  10. #70
    Dec 2003
    Quote Originally Posted by jake2465 View Post
    Is there a difference between one 100 pin connector and another? I am looking at some options for buying them and I am noticing that one kind has a plug that looks more square, while another type has a more rounded plug appearance. Both are said to be 100 pin cables. .
    The one 'more square' is probably the old style used on the DMC-1000 series, these are termed IDC connectors.
    Quite a few of the terminal manufacturers made break-outs terminal boards for these cables.
    Nov 2016
    Jim, I found my Anilam 1100 manual. It looks like it has every wire schematic that has anything to do with anything on it's electronics. I will scan and post those schematics here shortly so you can see what is going on with my setup. Some of them pertain only to the two axis system, so they may or may not have anything to do with my setup.
  12. #72
    Nov 2016
    Well, perhaps I spoke too soon. I imagine the schematics are copy righted. I don't know if I can actually post them online come to think of it.
  13. #73
    Dec 2013
    Probably not a good idea, not sure how all that works.
  14. #74
    Nov 2016
    The Phoenix Contact 5602077 came in today
    Analog drives for DC motors that run encoders?-phoenix-contact-5602077-jpg
