I tried the manual, and the techs at Mitsubishi, but I cannot figure out what is causing this error to display/cycle. The machine comes up in an "edit not-ready" state after the E-stop is cycled. This is on a Ecoca Lathe with a ITRI PC controller on it. There are only two E-stop switches on the lathe it is on, and both with cycle the relay properly. There is only 1 physical limit switch, it is on the Z axis, and limits range when the tail stock is in the way, it cycles the relay properly as well. There is a chuck guard switch and a door switch, both test out ok, but are not in use. Does anyone have any ideas?
Re: Help decoding this Mitsubishi spindle amp error
PING* bringing this up again as I am at this machine to try to figure this out once and for all. If anyone can help it would be a huge help, and maybe I can send some beer money over for the time.
