HI,
I have n ANCA Rgx machine , its A axis Rotory motor ecoder failed.
i want to replace this encoder , It is a siemns made motor for ANCA. With analog incremental encoder(Heidenhain ERN 1387.001-2048) .. ( I can buy Exactly similar encoder ) I'm not confident that i can replace it , reason is..
I know to replce it mechanically,(By following https://www.automation.siemens.com/W...96&Language=en But i think there is something more than mechanical alignment.what are all things other things i hav to take care about this encoder replacemtn . Kindly help me
Aligning ERN 1387 requires facility and eqipmnet to Record the Encoder Mechanical angle and Electrical angle. We own such equipment and use thse for Servo motor repairs/ Encoder alignment at UAE. In case you are based here or could send motor in .. We might help.
