Brother TC229 retrofit, can I keep the original servo drives
Results 1 to 13 of 13
Thread: Brother TC229 retrofit, can I keep the original servo drives
    Jun 2007
    canada
    Default Brother TC229 retrofit, can I keep the original servo drives
    I have a perfectly functional Brother TC229 with a conversational control that I would like to replace with LinuxCNC, I plan to use this machine as tool to make money and am prepared to spend several thousand to get it to work, including making the toolchanger and rigid tapping functions operate.
    The servodrives seem to be some customized variant of a Sankyo Denki PZ series drive. Unfortunately a manual or even a pinout of the drives in this machine does not seem to be available, Sankyo Denki is not too interested in providing me with any documentation.
    My plan is to build a special wiring harness (15 pins) to place between the controller and the drives to try to determine what signals are being sent between the two. Is this totally mission impossible? Has anyone else accomplished such a thing? what I can I expect the command signal from the controller to the individual drives to look like? The X, Y and Z amplifiers all have the same part number, where do the servo tuning parameters (which must be different for each axis) reside?
    If interfacing with the existing drives is too ambitious, can I at least keep the motors and replace the drives with ones that have full documentation?
    Jun 2007
    canada
    Spent a few hours making a special cable to allow me to probe the wires linking the controller to the amplifier with an oscilloscope and have come to the conclusion that the there is some form of serial communication between the two. There is also the A, B and index encoder pulses. I could find any evidence of analogue signals or step and direction signals.
    Stan
    Member Tkamsker's Avatar
    Oct 2010
    Austria
    Hi I did/Do similar of an Bridgeport 412 interact we ended up only using Old servos and use Generalmechatronics and granitedevices New encoder and you Are done i write an carousel Type atc component right now Thomas
    Gesendet von meinem SM-N9005 mit Tapatalk
    Dec 2003
    I believe these are controlled under the serial method called Sercos.
    SERCOS (Serial Real-time Communication System).
    Jun 2007
    canada
    Quote Originally Posted by Al_The_Man View Post
    is there a source for this notion?
    i ask because i have a tc229 on its way and can find zero info on it and sercos doesnt seem to have been adopted widely until after my machine was built though i guess brother could have been an early adopter. my tc225 is analogue, and every other brother model of the era (mid 90's) seems to also be analogue.
    Jun 2007
    canada
    Default Re: Brother TC229 retrofit, can I keep the original servo drives
    testing 123 - odd, this thread didnt get flagged as updated.
  7. #7
    Dec 2003
    I have no info on SERCOS just remember it vaguely coming across it from a few decades ago.
    Jun 2007
    canada
    ah, ok.
  9. #9
    Jun 2007
    canada
    edit: i didnt read well enough. :P
    so, the chips on the motherboard are rs422, proprietary sanyo.
    sanyo ga1022 chips.
    heres the paper that mentions them:
    https://www.sanyodenki.com/archive/d...TR28e_j_en.pdf
    https://www.sanyodenki.com/archive/d...TR10e_d_en.pdf
    https://www.sanyodenki.com/archive/d...TR16e_h_en.pdf
    ga1045 and ga1060 are similar newer chips.
    so, how are we going to get this to talk to linuxcnc? hmmm.
  10. #10
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by sbaer View Post
    Stan
    This may be of some help if you don't already have it
    Attached Files Attached Files
    Mactec54
  11. #11
    Jun 2007
    canada
    page 84
    http://www.sanyodenki.biz/products/I...7910-GA-en.pdf
    talks about the ga1060 protocol. i suspect its very similar to the ga1022, just faster and more payload.
  12. #12
    Jun 2007
    canada
    yes and no. yes, its of help to see the signals in action. i can make my own though. no, its of no help in that it doesnt actually tell us the commands that linuxcnc would have to send it. otherwise stan would have done it instead of replacing his drives
    it does seem that the encoder feedback is separate from the serial connection. so the serial is likely sending a speed command, and getting back some extra info like alarms, torque load, settings, etc.
  13. #13
    Jun 2007
    canada
    http://www.sanyodenki.biz/products/I...B_Manual_E.pdf
    so, this may be enough info to begin some tests. i think the 1060 and 1045 are basically the same, but faster/more data per transaction. the 1022 is different in that it is not synchronous, but otherwise, it seems to be similar, but slower / less data.
    might be good to try to splice in something like an arduino to "capture" a bit of the serial input/outputs as the machine turns on, then moves around. then we can see if we can get the framing and try to figure out the signals based on the ga1045 and ga1060 specs.
    and if that does work, i hear yaskawa makes nice servos :P
