FMD2740A problem
Results 1 to 4 of 4
Thread: FMD2740A problem
    Aug 2012
    Germany
    Default FMD2740A problem
    Just to document this.
    The FMD2740A is rated for a power supply of 12-50V.
    I just had a Chinese one blow up and it seems that inside a 5V step down regulator was used that is only rated for 6-45V.
    There is an extended range version for 6-60V so it is possible that other units with the proper chip exist.
    If anyone uses these with a 48V supply, check that the Linear Technology chip in the upper right corner ends in LM2576HVS-5.0 instead of LM2576S-5. 0
    Apr 2012
    I found this thread from searching "FMD2740A". Would you consider this lot 3pcs Stepper Motor Driver | eBay part of the Chinese knock-offs?
    How do you find the performance of them?
    What are you using for a controller / break out board?
    ~ What is your thoughts on the board included in that link?
    Thanks! Tyler
    Aug 2012
    Germany
    There's no way to know.
    Gesendet von meinem INO_ONE_PLUS mit Tapatalk
    Aug 2012
    Germany
    Nice...my replacement FMD2740A failed because of a bad solder connection on Capacitor 1.
    It's moving freely.
FMD2740A problem
FMD2740A problem
