Originally Posted by
jamesbond007
Hi, I'm trying to get this Yaskawa Drivers and Servos to work with Mach3, I have built other cnc Machines but with steppers, Drivers are SGDH-04AE, and servos are SGMAH-04AAF41, so theyre a match.
I have tried joging these from the Driver itself with success, all of them work, and I've been doing some testing trying with Mach3 to control them with some suggestions on the wiring.
Does anyone knows if I have to configure the driver to put it in a step/dir mode?, it has this configurations FNXXX , for example in FN002 is the Jog mode.
What pins on the CN1 connectos should I connect the step and dir signals from the paralel port? I have several options, PULS and /PULS, SIGN and /SIGN, CLR and /CLR, V-REF and T-REF, etc.
Here are some pictures
