Results 1 to 6 of 6
Thread: Post Using R instead of I,J
    br1
    br1 is offline
    Oct 2006
    Is it possible to change my Mach3 post processor to output an R instead of an I,J ? It seems to me you would have a much shorter code.
    br1
    br1 is offline
    Oct 2006
    hum
    Mar 2003
    Shelby Twp, MI....USA
    What CAM software are you using?
    br1
    br1 is offline
    Oct 2006
    Vectric Cut2D I think I found my issue I had to change I,J made to Incremental that worked but still would like to use r as as it shortens up the code
    Mar 2003
    You can modify the post to output R arcs, but it won't make the code have fewer lines, just slightly shorter on lines with arcs.
    R arcs can sometimes cause problems, especially with arcs over 180°. IJ arcs are a better choice imo.
    br1
    br1 is offline
    Oct 2006
    Yes you are right I found that out I really am not saving much. Thanks
    1. Replies: 0
      Last Post: 10-26-2006, 05:59 PM
