Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
  #121
Old 05-31-2009, 08:38 AM
ger21's Avatar
i found out that the Contact Led in the Z auto zero screen is not working
I think I fixed it. Can you download it again and try it? Also, I downloaded it, and the .pdf is in there.?? In Winzip, it's the 2nd file from the bottom.
Same Link.
http://tinyurl.com/pz8az9
  #122   Ban this user!
Old 05-31-2009, 11:28 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Bruno, something else is up besides the screen. Contact works great for me!
I'll be posting a bit later with some more details (photos still on camera this morning, and I have a video too), but the probing seems to work fine as far as I can tell.
Cheers,
BW
Old 05-31-2009, 11:32 AM
ger21's Avatar
I changed it to what Ernie had in his MachBlue. System Function Probe. It was set to OEM 825, which is Digitize In. They should be the same, though. Let me know if it's OK or not.
  #124   Ban this user!
Old 06-01-2009, 04:18 PM
mindstorm88 is on a distinguished road
Ok guys , it is working , even if my probe was working for auto zero , it seems that my router ground was not good, as soon has i touch the probe to the controller ground the contact led turn on , so sorry Ger , i was the problem !!!!
  #125   Ban this user!
Old 02-16-2011, 01:40 PM
dpaish is on a distinguished road
Great Screen Set
Would it be hard to link the Select Wizard to execute the NFS Mill Add On?
I rarely use he standard wizard, but use the NFS Mill Add On daily.
Regards,
Dennis Paish
Old 02-17-2011, 07:06 PM
ger21's Avatar
Here's a modified .set file to do what you want.
  #127   Ban this user!
Old 02-20-2011, 09:54 AM
Vegabond's Avatar
Vegabond is on a distinguished road
Hello, i try this. But the screen isn`t right... Why?
Greetings from Robert.
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
Old 02-20-2011, 10:36 AM
ger21's Avatar
You don't have all the bitmaps. The .set file I just posted was not the full installation. Here's all the files.
The CNC Woodworker - Mach3 Aqua
  #129   Ban this user!
Old 02-20-2011, 11:06 AM
Vegabond's Avatar
Thanks!
Where is the folder for the brain files?
I put the aqua map in the bitmap folder and the set file in the subfolder Mach3, is that right?
Thanks...
Robert.
Old 02-20-2011, 12:53 PM
ger21's Avatar
Mach3\Brains\
If you don't have it, then you probably have an old version of Mach3, and it doesn't support brains?
screen larry53 Computers and Networking 15 11-28-2009 05:03 PM
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 06:35 PM
I think the screen on my 6T is going out protrxrptr17 Fanuc 5 11-06-2008 06:23 PM
how to set a touch screen on the screen of mach 3 cob Mach Mill 6 07-13-2008 05:28 PM
SL-20 big screen ? Jones_69 Haas Lathes 0 09-01-2007 07:12 AM
