Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 10-30-2008, 10:59 AM
tmead is on a distinguished road
Macro to run when screen is opened
Is it possible to run a macro when a screen is opened ? I have a row of four buttons that load the four Gcode files that the user will be allowed on the machine, and a row of four userLEDs that indicate which file has been opened (which button has been pressed). When Mach is started no file has been opened, so no LED should be lit. I can't get away from the condition that one of them is lit.
I also have an array of buttons/LEDs layed out for a set of fixtures, and the LEDs show which fixture is active (which button has been pressed). Unfortunately, changing to another screen, swapping to a different fixture (G55, G58 etc) and then changing back to my screen doesn't update the LED.
A macro that ran when the screen was opened could fix both of these !
Tim
Old 10-30-2008, 11:24 AM
ger21's Avatar
Can you have a macro change your screen? Not sure, and don't have time to check right now. Just a guess.
Old 10-30-2008, 02:07 PM
Yep, a macro to change the screen would be just fine. I'm exposing the limits of my ignorance here, but is there a way of attaching a macro to the screen so that it runs once when the screen is opened ? I could do it by putting a button on there to initiate the 'update all leds' macro, but I'd like to do it automatically when the screen is switched.
Tim
Old 10-30-2008, 09:22 PM
ger21's Avatar
DoOEMButton(X) will change the screen to screen X. Try that as the first or last line of your macro, and assign the macro to the button to change the screen. Then it should change the screen and run the macro, or maybe run the macro first and then change the screen.
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 07:35 PM
how to set a touch screen on the screen of mach 3 cob Mach Mill 6 07-13-2008 06:28 PM
Convert Fanuc Macro to Fadal Macro bfoster59 Fadal 1 11-09-2007 12:41 AM
CNC Operators and Programmers Jobs Season Opened CanroIntl Employment Opportunity 1 08-29-2007 05:59 PM
Classifieds has been re-opened CNCadmin CNCzone Site News and Contests 7 07-26-2007 09:13 AM
