Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 12-07-2007, 09:49 PM
carlnpa is on a distinguished road
Does anyone have the Mach 3 screenset
Does anyone have the mach 3 screenset that was the same as that used in Mach 2? It would be greatly appreciated. I production mill nested plastic parts in Mach 2, the Mach 3 screens require me to change my routine and I have too often trashed a tray of parts in very expensive polymers in Mach 3, so I keep using mach 2. Help would be appreciated.
Old 12-07-2007, 10:13 PM
jhowelb is an unknown quantity at this point
well, the zone won't let upload without some "magic"!
Put them in the appropriate folder then take the .txt off the file name.
Old 12-08-2007, 09:04 AM
Hi jhowelb
The files were converted to txt type files from the .set type.
The Mach screenloader doesn't recognize them.
So close.
Old 12-08-2007, 09:24 AM
ger21's Avatar
Just rename them, or when downloading and saving, rename them then. In the save dialog, for the filename, save as "1024classic.set" Include the quotes and set file type as all files, not text.
Old 12-08-2007, 10:40 AM
Thank you all, the "" "" did it, new screens were working until I killed Mach 3.
In loading the screens I killed Mach 3, it opens to a blank white screen now with the file conf etc tool bar on top, nothing else. Nothings alive I can open the tool bar operators but nothing works, can't load a screen etc. Ideas?
Old 12-08-2007, 10:44 AM
Is it possible I put in a password in the lock unlock. Previously it was none or not required, now it say mach 4 wrong password?
Old 12-08-2007, 10:51 AM
Choose view on the toolbar and then load screens, navigate to the set you want.
Also you need all the bmp's from the Mach 2 set in the proper directory.
Maybe you could do a reinstall and then use screen4 to modify the screens to give what you want?
DO NOT use quote marks in the file name, just get rid of the four characters .txt
Old 12-08-2007, 11:09 AM
The load screen bar will not initiate, it won't enable. Its not the screen set they were working fine, I must have "touched" something else in machmill 3, all the other programs are fine (turn, plasma). Some of the menu bar items are enabled, most are not.
Old 12-08-2007, 11:14 AM
Put your screen set that I sent you in a new folder in The Mach folder then reinstall.
Sound as if some file is corrupted,
Old 12-08-2007, 11:32 AM
I don't think this problem has any relation to the screens, I must have "touched" something else in the program. The screens were working fine, and are just what I am looking for. I really do appreciate your help with this.
  #11   Ban this user!
Old 12-08-2007, 05:40 PM
jhowelb
You caught it, "screen file must" be in the mach folder.
Even though you can load it from a folder outside the mach folder, it won't restart on the desired screen, starts on the blank screen and won't allow loading. The screen is very nice, thank you, identical to the Mach 2 screen I have.
  #12   Ban this user!
Old 12-08-2007, 06:11 PM
Nada prob bud!
1st 'Beta' release of the MachSteelBlue Screenset santiniuk Screen Layouts, Post Processors & Misc 19 10-14-2007 11:48 AM
Mach3Turn - 1st 'Beta' release of the SilverBlue Screenset for lathes santiniuk Screen Layouts, Post Processors & Misc 4 03-08-2007 10:55 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 05:41 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 04:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 12:44 PM
