Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 08-23-2007, 09:47 PM
EL34 is on a distinguished road
Screen layout problem
I designed a mach3 screen with screen4 on one PC and it displays fine on that PC.
I copied the background.jpg image used in that screen and the customscreen.set file to the actual machine I use mach3 on, over my network. The .set file is in the mach3 folder and the background.jpg is in a folder under the mach3/bitmap folder.
I open the custom screen on the mach3 pc and it's all messed up. Hard to describe but it looks like the screen is split in the middle and there are two sets of buttons on the screen. Nothing is in the proper location.
It looks fine on the design PC but not right on the actual machine PC.
What should I look for to correct this. Not sure where to go from here.
Old 08-23-2007, 11:24 PM
Greolt is on a distinguished road
The first thing I would suspect is that the background.jpg is not in the exact same directory path.
If you are sure that is correct then the next thing would be the Mach version you are using.
I have had a version, as I update to the latest usually, that did a similar thing and when I went back to a previous version all was OK.
So if you're not on the latest lock down version already, then try that.
And if you are already, try stepping back a version or two.
Greg
Last edited by Greolt; 08-24-2007 at 12:38 AM. Reason: May have been incorrect info
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 07:35 PM
Acramatic 2100/Cincinnati Lancer - Touch screen problem! Per O. Machine Problems, Solutions , Wireless DNC, serial port 10 02-08-2009 05:19 PM
Screen reolution problem George Mach Mill 3 01-26-2006 08:39 PM
Layout Dye mjarus General Metalwork Discussion 5 12-31-2005 12:06 AM
