Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 01-25-2006, 08:51 AM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
5 Axis Mill Sreen set for Mach 3
This on is for Mach 3, and works with upto version 1.84 (last lock down release).
The only page I didnt modify was the Positioning page, (since I have found that I didnt need a 5th for getting a part set).
The screen "Back ground", is not fancy, just functional.
I added 5th axis Jog/MPG buttons on the TAB fly out, but Art said he will have to add OEM code, so the buttons will work, they currently don't so, when he adds the code, and tell me what the OEMs are, I will redo the buttons.
scott
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 01-25-2006, 08:56 AM
tjstraz's Avatar
tjstraz is on a distinguished road
Cool! How about a screen shot so we can see the layout before downloading?
Old 01-25-2006, 09:06 AM
Opps, sorry forgot to do that, here it is........
Mach 3 Five axis mill Screen shot.
scott
Name:	Mach 5 axis screen shot.jpg‎
Old 02-08-2006, 08:51 PM
Little glitch, noted.
Some of the newer Mach3 download versions, Don't have some of the previous versions bitmaps........ If you use the screen set, and when you load it, if you see a funky white back ground, and it looks like some horrible virus ate your computer. Don't panic, your just missing the Bitmaps that the set was designed with. The older ones you will need are: Green-Gray Recessed, Green-Gray raised, and Grey button.
all you have to do, is copy an older bit map file that has them, OR, if you are used to using Screen designer, just click on the strange background white objects, and load in its place a bitmap you do have if for some reason you cant get older bitmaps.
Or, ask Art, to supply you with the bitmaps.
scott
Old 02-23-2006, 08:17 PM
Ok,
Here is the 5th axis screen set with working 5th axis jogs on the Tab out. You need at least Developmental version 1.90.013
Furhter I have enclosed the needed Bitmaps in a "Bitmap", file, you will need to copy these out of this file and paste them into your Bitmap file Under mach 3 "Bitmaps".
scott
File Type: zip Mach 3 Fifth axis screen set with working jogs.zip‎ (131.8 KB, 704 views)
Old 03-11-2009, 04:36 PM
wyobmf is on a distinguished road
Are you doing 5 axis machining with mach 3? Or is it just jogging functions?
I was told that mach didnt support 5 axis.
Old 03-12-2009, 08:44 AM
Yes,
You can do upto 6 axis machining, BUT here is the caviot. Mine is set up like a Trunion table type like a 3+2. If you want to do "Continous 5 Axis" then you would need to have a CAM program that could post it all out. Mach itself does NOT (currently) do Axis Translations (like if you have 4/5 on your Spindle). There are no G Codes for doing Axis Translations (Kinimatics). So all of that load would fall on your CAM package.
I use OneCNCXR2 Mill that has a "Positional or Continous 4th" and a Positional only 5th.
Scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
Old 03-12-2009, 08:47 AM
Oh one other thing....
The screens here are REAL OLD!!! way back in the early days of Mach, there is a guy screen named "Darc" on the Mach Support site www.machsupport.com that Redid the screens and made them look MUCH, MUCH better. I am NOT a good or even average "Graphics designer" but Darc is, and now I use his version of my screen cause it looks Sooooooo much better! He even put out a 6 axis version of it, (that I also use )
scott
Old 03-12-2009, 09:08 AM
mcphill is on a distinguished road
Originally Posted by PoppaBear10 View Post
Yes,
Could I ask you to elaborate on this? With a 3+2 setup, where are the two additional axes? I assume one is a "lathe spindle" orientation along the X axis. Where is #5? Also, are you saying it steps the 4th and 5th axis and does a pass (no kinematics) or what do you mean, exactly. I have BobCAD, which I know does 4-axis, and I think does 5-axis GCode generation. Would these files work?
Old 03-12-2009, 09:22 AM
From what I gather, It is double rotary tables. One wraped on the y axis and one on the X axis.
Poppabear,
I have access to a CAM package that will output 5 axis G-code in the dual rotary table config. It only has a few post proccessor options but maybee I could tweek it to work with mach. So my question is if you have a CAM that will output 5 axis G-cdoe in the 3+2 configuration then mach can do 5 axis just fine?
  #11   Ban this user!
Old 03-12-2009, 12:16 PM
Mach will run what G code you send it. If you CAM will put out 4-5 axis moves, as long as they dont require your CNC control to do Axis Translation codes, then Yes you can run Positional or Continous tool paths.
I run as I said above a 3+2 type set up (like a Haas Trunion Table) 5th axis. My CAM will not do "Continous" 5th axis work, i.e. like cutting a complex Turbine compressor like on a turbo charger.
But there are CAMs out there that DO continous 5 axis, and you can run that to, IF that software does all the "Axis Translation" in the software and does not post out any Specilized Canned G-Code Axis translation tool tip offsets.
scott
