Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 02-26-2011, 09:45 AM
Brainfreeze's Avatar
Brainfreeze is on a distinguished road
Mach3 Punch Press Screen Needed
Does anyone know where I can purchase a Mach3 screen for a Strippit 30/30 Super A/G 2-axis non-turret punch press or should I consider making one myself? The main functions I need are Home, MDI, Jog (^v><), Grid corner specified (pattern), Bolt hole circle (pattern), circular nibble (pattern), and Stop. I would probably use zero functions for X-Y if I had them, but I don't have them know. Ideally it would be nice to have a touch screen, but it is probably out of my budget. I have attached a picture of the old burned out controller.
Also, I have started a forum with some questions on my punch press project and I would appreciate any and all advise / input, so please stop by my forum.
Name:	2011-02-07 17.09.32.jpg‎
Old 07-05-2011, 02:06 AM
zafarsalam is on a distinguished road
I did a retrofit of a CNC turret punch press 2 years ago. It's video is available at YouTube - ‪CNC Turret Punch retrofit with Mach3‬‏. Your punching must be hydraulic powered, for it you'll need macro programming using the inputs from different position sensors and outputs to solenoid valves. I can provide the screens but the macro programming is totally dependent on machine design which you'll have to handle yourself.
Zafar
Old 07-09-2011, 10:38 PM
Zafarsalam, thank you for your reply. My machine is a simple non-turret machine that is driven by two rotating flywheels with no hydraulics. My machine also only has a x-axis and y-axis that are driven by two separate stepper motors connected to a worm drive and an optical encoder on each for position feed back.
I got the original controller working since my last post, but I would still like to replace it with a newer controller and I am considering writing my own gui based software for this machine and modeling it on the original interface with some improvements. I want to keep the software simple, I don't want to have to hire or train a G-code programmer just to punch and nibble holes, that would be counter productive in my case.
Old 07-09-2011, 11:20 PM
Mach3 would be best to send pulses to the stepper motors. If you have experience with Mach3 then you can design a custom screen for your application and also program wizards for common punching tasks which can automate the process of generating g-codes.
CNC punch press software Uglybob General CAM Discussion 23 08-20-2011 10:47 AM
CNC benchtop punch-press 307startup CNCzone Club House 9 12-06-2010 08:07 AM
CNC Punch press plans metalworkz General Metal Working Machines 22 12-06-2010 07:52 AM
pullmax 211 punch press simplextibi34 Controller & Computer Solutions 0 05-13-2010 03:14 PM
