Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 07-19-2005, 09:58 PM
rktknife is on a distinguished road
Mach 2 help
We are new to CNC work and have a 3 foot by 4 foot router. Running Art of CNC mach 2 soft ware. When we inport a drawing in to the software the machine goes to the far limits and limits out before it gets to the item to mill in drawing. From the screen view it looks like the item to mill out is a dot in the corner of a large field. It seems the drawig field is too large and we also do not know how to call a start or zero point. Probably all simple items for someone use to CNC but as I said we are new. If anyone has screen shots of Mach 2 set ups it would be of great help also.
Marty@RKTknife.com
Old 07-19-2005, 10:49 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
I am wondering if you are importing a Metric Drawing into Mach2 but have the units in mach2 set to inchs. This means a 500mm drawing will become a 500 inch cutout. A huge difference hey?
Let me know if this was the problem.
Old 07-20-2005, 10:49 PM
Thanks for the idea, We tied both a metric and inch drawing and checked the setting on each even changed them to see it seemed to make no differance. This may be a more CAD problem than Mach 2 I am not sure but welcome any help trying to track it down. We are also open to any other control soft ware if some feel it is better.
Old 07-20-2005, 11:16 PM
rc-cellar is on a distinguished road
sounds like not zeroed...
Jog router to lower-right corner (or Home if you have switches)
Load drawing, hit ZeroX ZeroY ZeroZ (or ZeroAll) then Regenerate Toolpath
Mach2 is the best...keep it!
If it ain't broke... fix it 'til it is.
Old 07-21-2005, 12:48 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
Sounds like the coordinates of the actual drawing file is not close to 0,0,0, you need to move the drawing file to the desired X=0, Y=0 and Z=0 in your cadd program 1st, then generate your g-code.
Look and see what is the coord's in the g-code is to start with, or post your drawing/g-code here so we can look at it.
Joe
Old 07-21-2005, 07:08 AM
ger21's Avatar
Could you post the drawing here?
