Page 11 of 65 FirstFirst ... 8910111213142161 ... LastLast
Results 121 to 132 of 773
Thread: Mach3 2010 Screen set
  1. #121
    Mar 2003
    Shelby Twp, MI....USA
    How did you get around your grounding issue?
  2. #122
    Registered revwarguy's Avatar
    Feb 2009
    Still using a clip-on clamp on the collet nut, but that's pretty clumsy now, especially having to be right there to grab it right after the tool change setting, so I do intend to do something about it. Before, I guess I was reluctant to run a wire down near the collet just because it would get in the way of removing the router when necessary, and the way the mount surrounds the case. Now, with the mod for the SuperPID and its wire, I guess that's kind of silly. I'll be attaching one to the base soon.
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
  3. #123
    Mar 2003
    Added simple auto zero
    I added a download link on my site for an alternate "simple" auto zero macro.
    For those that don't need the toolchange auto zero and 2 plate setup, this will allow you to just do a single auto zero.
    It also still supports the optional material offset, and the retract height is user definable via the Clearance Plane DRO.
  4. #124
    Registered Arbo's Avatar
    Jan 2008
    Is it an either/or thing, or can both be used in the same screens?
  • #125
    Mar 2003
    One or the other for right now, but if you want both, I can add another button on the toolbar I guess.
  • #126
    Jun 2003
    tagged
    No greater love can a man have than this, that he give his life for a friend.
  • #127
    Feb 2009
    Well, it seems the Colt uses some kind of ceramic bearing. I have no connectivity between the collet and bit to any part of the case. Not sure now how to avoid having a clip on the collet when zeroing.
  • #128
    Mar 2003
    I wouldn't think it's a ceramic bearing, as replacements are only $5. (I just checked)
    Looking at this pic, http://www.ereplacementparts.com/ima...2609110220.gif it looks like the bearing is mounted in plastic to isolate it. Perhaps you can disassemble it, and drill a hole and get a wire to contact the outside of the bearing? Just a guess.
  • #129
    Feb 2009
    Not a bad guess, thanks for checking, Gerry. Perhaps I'll try to squeeze something in there. Probably ought to change the bearing as long as I'm there, anyway.
    Actually, I'm doing this only because I don't want to change the mount. If I did, what is the "cleanest" router for grounding/SuperPID mods - I mean easiest to do? Any feeling for that? I went with the Colt only because it was light and had the best runout.
  • #130
    Mar 2003
    New Feature
    Anyone have a use for something like this?
  • #131
    Jan 2008
    I don't use that stuff too often, but I'm sure others probably do. The only thing I was going to do, when I got a chance, was make a little Icon to put on the top bar by the M6 stuff for just a normal z autoprobe like I used to do before the tool change. Figure every now and then I'll still be using it. Add the newest z code to the button and all.
  • #132
    Registered Jason3's Avatar
    Aug 2007
    New Zealand
    Absolutely.
    I think it would be extra useful if there was a setting for probe offset so that I could use a non-spindle mounted probe. I'd need to work out how to activate it though (I want it to retract when not in use).
    Regards,
    Jason
  • Page 11 of 65 FirstFirst ... 8910111213142161 ... LastLast
    1. Need Help!- I need to write what file i want to open.... how can i change to the "old" screen?
      By Vegabond in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 12-03-2010, 07:55 AM
    2. no "jog" screen in mp3000-dthc-ubob profile
      By creepy in forum Mach Plasma / Laser
      Last Post: 01-18-2010, 07:40 AM
    3. Replies: 5
      Last Post: 08-12-2009, 08:14 AM
    4. Searching "Haas" Screen
      By Dano Andry in forum Screen Layouts, Post Processors & Misc
      Last Post: 04-18-2009, 03:08 PM
    5. TUTORIAL "How to make a screen capture."
      By ynneb in forum Forum Questions or Problems
      Last Post: 06-14-2005, 05:12 PM
