Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 06-08-2010, 08:15 PM
Claude Boudreau is on a distinguished road
Red face gcode screen
I ve been using mach3 for a few year without any problem except for this.
I cant remember the right name for what I will call the gcode screen, my problem is the letters seem too large ,so the bottom part of the letters are cut off on the display and make a Z look like a 7... making everything kinda hard to read , especially for a novice trying to decipher gcode.
Any help will be appreciate.
Old 06-08-2010, 08:50 PM
Big-tex's Avatar
Big-tex is on a distinguished road
Try changing font size in Functions Cfg's under Fonts
Old 06-09-2010, 11:37 AM
Unhappy does not register
thanks , I m making the font size change then click ok ... nothing happpen ... dont seem to register.
Old 06-09-2010, 05:29 PM
ger21's Avatar
The Font size can't actually be changed. The Font control is only for changing the Font itself.
Is every line cut off, or just the bottom line? Have you changed the Font from the default?
One thing you can try is changing the font size in the Windows display settings. Right click on the Desktop, choose Properties, and poke around until you find a Font setting.
Old 06-09-2010, 10:24 PM
Unhappy confusing fonts
Hi ger21,
yes every line in the gcode display are cutoff at the bottom.
This does not look to be a windows problem as the dro and the other displays are ok.
Now Im confuse , if you select Font, under the Function cfg s, a window named
Select the font for various controls appears, with 4 buttons named
DRO------- 18pt arial
Label------ 18pt arial
Code------ 18pt arial
Buttons---- 18pt arial
by clicking these a font window appear with selection of font type , style, and size.
I do the change in size and click ok but I dont see any change.
I did not change anything it was like that when I first installed Mach 3.But what default are you refering to?
Old 06-10-2010, 10:54 AM
ger21's Avatar
None of those settings will change except the Font itself, and only after you restart mach3. Did you change the font? I'd try a different font.
Old 06-11-2010, 05:51 AM
Wink solved
After trying many other fonts without success I found that the font named Courrier does the trick.
After taking a better look at the other display, I see that they are all cut off on the bottom , just dont look as bad in numbers than letters.
Thanks , was really tired of seeing FILE displayed as FII F
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 06:35 PM
how to set a touch screen on the screen of mach 3 cob Mach Mill 6 07-13-2008 05:28 PM
SL-20 big screen ? Jones_69 Haas Lathes 0 09-01-2007 07:12 AM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 06:51 PM
