Results 1 to 8 of 8
Thread: SimpleMill - A very simple 3 axis screen set
    Jan 2009
    SimpleMill is a simple three axis screen set for Mach3. I use about 1/10 of the stuff that is on most screen sets with my milling of Experimental Aircraft parts.
    If you are a Mach3 user, and do a lot of 2.5d CNC milling, this may be the screen set you have been looking for.
    Check it out at: http://www.mrrace.com/SimpleMill/
    George
    br1
    br1 is offline
    Oct 2006
    Hey, I like the full screen, but do miss the ref all button. Nice, Very basic.
    Mar 2003
    Shelby Twp, MI....USA
    Looks kinda familiar.
    Jan 2009
    Quote Originally Posted by ger21 View Post
    Hi Gerry:
    You can probably see that you were the inspiration I needed to learn machscreen and do what I did. I live west of you in the Albion MI area.
    George
    Jan 2009
    Quote Originally Posted by br1 View Post
    Is that the Force Reference All function 246?
    If you think that would be a good addition to a very basic setup I will find a place to add it in.
    Thanks for the suggestion,
    George
    May 2009
    Hi George,
    I set the 3 axis screen in mach3 but it is not working correctly.
    the letters and numbers are not showing up.
    How do I install?
    Jan 2009
    Installing SimpleMill
    Quote Originally Posted by kasari View Post
    Hi George,
    How do I install?
    Hi Kasari:
    I am not sure what you mean, but here are the steps to install and run SimpleMill in your Mach3 folder.
    Download the SimpleMill.Zip file from my site.
    UnZip the file and you will have a folder called "SimpleMill" and two additionals files that end with .set. One is a three axis the other a 4 axis.
    Next copy the complete "SimpleMill" folder into your Mach3 "Bitmap" folder. Then copy the two .set files into your "Mach3" folder.
    Start Mach3, click on view, load screens, and select the .set file you wish to run.
    Let me know if you are still having problems.
    George
    br1
    br1 is offline
    Oct 2006
    Quote Originally Posted by GeorgeRace View Post
    George
    Yes I believe thats the one. I am using your screen on one of my setups, I like it, you don't need to change it. Myself, when I start my machine, I like to push the ref all button to send all my axis to home, it is not a big deal to not have it as I have a simple nc file to open to do this. Again nice job.
    1. What do you want in a simple Mach3 router screen?
      By ger21 in forum Screen Layouts, Post Processors & Misc
      Last Post: 08-03-2008, 04:54 PM
    2. Problem- Axis Drive Off On Screen -Will Not Home
      By MTech2 in forum Bridgeport and Hardinge Mills
      Last Post: 04-17-2008, 03:52 PM
    3. Need Help!- 6 axis screen of mach3
      By ayhan in forum Mach Software (ArtSoft software)
      Last Post: 02-21-2008, 05:24 AM
    4. A Simple 4th axis
      By mocnc in forum DIY CNC Router Table Machines
      Last Post: 02-20-2007, 10:59 AM
    5. New 5 axis screen set I've been working on
      By Darc in forum Screen Layouts, Post Processors & Misc
      Last Post: 04-10-2006, 03:38 PM
