Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 03-08-2010, 02:16 PM
jrslick22 is on a distinguished road
Newbe: edit tool change script
I have downloaded and installed the post for Bobcad, the standard change tool script is this:
'Tool Change
NCEdit Output,Line = i
dim TOOLNUM as string
dim DESC as string
Ask Header="Tool Change",Output,Cancel=canc,"Tool Number:"=TOOLNUM, "Tool Description"=DESC
If canc Then
Exit
End If
NCEdit Line = i,Output,Text=txt
txt = "T"+TOOLNUM+"M6"
If Len(DESC) > 0 Then
txt = txt+"("+DESC+")"
End If
NCEdit Line = i,Text=txt, Output, NumLines=nl
NCEdit Line = nl+2
NCRenumber
Window2
I have a manual tool change setup so i need to have the tool change do a M00 so i can change the tool, can someone please help me edit this scrip so that it will also output this stop command.
thanks
Edit Tool Change Macro Oi-MC dtmtim Fanuc 4 09-21-2007 07:34 AM
Edit Post to use Tool Size Offsets on Controller lorindan Post Processor Files 0 08-11-2007 02:24 PM
How to change Tool change position(About MAZATROL T1 control) liushuixingyun Mazak, Mitsubishi, Mazatrol 5 07-07-2007 02:58 PM
EDIT O9000 tool change macro fanuc 0M mikul Fanuc 1 04-20-2007 06:06 PM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
