Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc
Old 02-26-2010, 11:24 AM
BevelingFool is on a distinguished road
Red face Mach3 DRO Reconfigure
I have a machine where the X axis is homed/zeroed all the way to the right and of course moves from right to left. Because all the movement is on the left side of zero, everything displayed in the DRO is a negative number. I would like to reconfigure the DRO so the display is reversed showing + (positive) numbers rather than - (negative) numbers. This would make it a lot easier on me because I hand code all of my G-code. I had Mach setup to do this until my hard drive crashed a few days ago and of course inadvertently reformatted the hard drive with the backup on it. I've been through all the settings hoping my memory would be jogged but no luck. All I can remember is that it was a very simple fix, of course. Any ideas?
Old 02-26-2010, 12:58 PM
spoiledbrat is on a distinguished road
You can change the homing/limit location to whatever you want (i.e. X= +120.000"). Within the Homing/Limits dialogue, there is a setting for homing negative.
Another option would be to reverse the X axis AND Y axis motor outputs. I think this is done with the direction signal (active low or active high).
Disclaimer!!! I have been awake for 36 hours. Will someone come along and educate us both?
Cheers,
Rob
Old 02-26-2010, 05:08 PM
That did the trick, Thanks
Tags
display, dro, mach3, reconfigure
Mach3 won't keep zero! sp1nm0nkey Mach Software (ArtSoft software) 17 09-06-2009 03:21 PM
New Machine Build- Mach3 mrpeja Mach Software (ArtSoft software) 0 12-30-2008 04:22 PM
Mach3 and USB snovak240 Machines running Mach Software 3 08-16-2008 10:06 PM
4to eje con mach3 dansa0561 Spanish CNCzone 3 07-31-2008 10:44 AM
Need Help!- Mach3 AngelT Mach Mill 5 06-28-2008 01:51 PM
