Need Help! Need a post for Fusion 360
Results 1 to 6 of 6
Thread: Need a post for Fusion 360
    Registered cncadmin's Avatar
    Mar 2003
    Default Need a post for Fusion 360
    I'm looking for someone to modify a post for me willing to pay. I have a post for Fusion 360 I need modified to work with my machine, I have a working post for sheetcam that i need to use to make the fusion post work.
    Thank You,
    Paul G
    Check out-
    [URL="http://www.signs101.com"]www.signs101.com[/URL]
    Mar 2003
    Default Re: Need a post for Fusion 360
    No one ?
    Thank You,
    Paul G
    Check out-
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    What do you need done
    <img src="https://ivxo1q-dm2305.files.1drv.com/y4mENMmTr_Cabc7pR0FUdB6gtbADq2JbuG4_rGy0eBQvLJx19pTi6TqMUIJN0xgOyDIc0gWoxYhS38HpbSTFGdfaK-o42IOU6jczrhDpfpCOTNGL1X6hvZCbgj0y35gqmq1YGTrWwShYGV-C7lXA2esy0Pi_WfnBSyroDLSGXwce4uSr1U7op7srdi78rispHCa_K4aFlTlJPVkkNWMfgh_Tg?width=60&height=60&cropmode=none" width="60" height="60" />
    Being Disabled is OK CNC is For fuN
    Mar 2003
    I'm using a sheetcam post which works with my router, and need a fuson 360 post to match. I have uploaded my to posts. My router uses a piston to lower the right spindle as I have 2 of them, than the z is operated with a ball screw as normal.
    Attached Files Attached Files
    Thank You,
    Paul G
    Check out-
    Sep 2009
    New Zealand
    You will be better off posting in the HSM forum here https://forums.autodesk.com/t5/hsm-p...forum/bd-p/218
    Or if you wont to pay for it and have support behind it get hold of this dude https://forums.autodesk.com/t5/user/...user-id/548578
    Mar 2003
    Great thanks!
    Thank You,
    Paul G
    Check out-
