Problem after install
Results 1 to 4 of 4
Thread: Problem after install
    Feb 2014
    Default Problem after install
    I installed the 2010 while following the video on YT, I have everything set up in Mach3 but once I chose the"view" 2010 screen, none of the controls work, no y /x z access movement at all, when I switch back to the Mach3 screen, everything works. I am not sure what I missed or why things aren`t working, but if anyone can guide me I`d appreciate it...
    Thanks R.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Problem after install
    Did you copy the macros from \Mach3\macros\2010 into \Mach3\macros\yourprofilename\
    UCCNC 2017 Screenset
    Feb 2014
    Hi Ger,Yes I did.
    Feb 2014
    Problem solved, all set now.
