Mach3 2010 Screen set - Page 114
Page 114 of 114 FirstFirst ... 1464104111112113114
Results 1,357 to 1,360 of 1360
Thread: Mach3 2010 Screen set
  1. #1357
    Mar 2003
    Default Re: Mach3 2010 Screen set
    I really don't know how to do that.
    One, I'm not sure you can have a message box window open during movement.
    You'd probably have to get the tool size from the tooltable.
    It would need to go in the M6Start macro, which basically just sends the tool to the toolchange position, and then waits for the M6End to run.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  2. #1358
    Apr 2015
    Hey Gerry, I have a problem I'm hoping you can help me with.
    For years I have been using your screenset and macros. The referencing all macro has been working just fine. My system has Z (going positive), X (going negative), and Y (going negative), then A (slave to Y).
    Just recently, because I am adding a laser, I changed the slave for Y to C. Even though the maching runs correctly with this setup when I try to reference all the slave (C) does not home. I changed the referencing macro (884)to the following but it didnt work.
    DoButton( 24 )
    ' Home Z
    'Code "G53 G0 Z-1"
    'While IsMoving()
    'Wend
    RefCombination( 34 )
    ' Home Y'Code "G53 G0 Y1"
    'While IsMoving()
    'Wend
    DoButton(22)
    ' Home Z'Code "G53 G0 X1"
    'While IsMoving()
    'Wend
    Can you see what I am missing"
  3. #1359
    Mar 2003
    Did you change your home switch settings in ports and pins, from A to C?
  4. #1360
    Apr 2015
    Quote Originally Posted by ger21 View Post
    Nope!!!! That was it. Thanks so much
