Mach3 2010 Screen set - Page 76
Page 76 of 76 FirstFirst ... 266673747576
Results 1,501 to 1,506 of 1506
Thread: Mach3 2010 Screen set
  1. #1501
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Mach3 2010 Screen set
    Quote Originally Posted by Eveb View Post
    Hello,
    This Mach 2010 looks pretty good.
    Do it works with chinese xhc mk4 ethernet board?
    Regards
    From what I hear from my customers, the XHC boards are one of the worst when it comes to running macros. I've had some have a bit of success using the Chinese macros on my website, but others haven't been able to get it to work at all.
    If you want to use the 2010 screenset, I'd only recommend an ESS or a CNC Drive controller.
    UCCNC 2017 Screenset
  2. #1502
    Nov 2013
    all development on Mach3 ceased eight years ago, as far as I'm concerned its obsolete.
    Mach4 is the replacement and is light years ahead, and is still and actively being developed. It won't work with crappy Chinese made motion boards.
    Craig
  3. #1503
    Member cortex_makes's Avatar
    Sep 2023
    Hi i just bought the screenset too.
    I now realised that it might not be available anymore ?
    Is this project still active.
    I'll try to send an email to him.
  4. #1504
    Member Jamesbond2285's Avatar
    Oct 2023
    Hi, I just bought and installed the screenset, and I'm having troubles with the auto tool zero script. My probe plate is 29mm tall (I don't have the exact number in front of me at the moment unfortunately) and when I enter that number, it changes it to -29.00. When a measure is executed, after the second, slower probe, it jams my tool into the plate. It looks like the highest + value I'm allowed to enter is +.999 for some reason. I'm using a puck mounted in place to my bed.
  5. #1505
    May 2005
    Croatia
    Quote Originally Posted by Jamesbond2285 View Post
    It works perfectly for me on an old CNC machine that has an LPT port, but now I bought a small new one with a BL-UsbMach-V22 USB controller and I have the same problem
  6. #1506
    Sep 2005
    Indonesia
    "a BL-UsbMach-V22 USB controller and I have the same problem"
    you can not slave axis ?
