Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Safety Zone
Safety Zone Discuss safety related issues about machines and materials.
Old 12-16-2009, 03:18 PM
lgalla's Avatar
lgalla is on a distinguished road
motor starters
Hi everyone,I never see any posts of motor starters.Every piece of machinery in the shop has motor starters as required by code.As i understand in the event of a power failure or blackout a relay or magnetic contactor will disconnect the line from the motor.Imagine a power outage while running a machine.Without the starter when the power resumes your machine powers up again.When is a starter required?They are expensive at least in my shop which has 575V3 phase.
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 12-16-2009, 03:24 PM
Al_The_Man's Avatar
Starters also known as Contactors are required as a hardware disconnect on all motorized machinery.
They range from ordinary single contact to specialized ones like reversers and Definate-purpose style (Air conditioners and welders/ plasma etc).
The DIN style are now popular due to their smaller size than the NEMA counter part.
They are pricey, A good source is Ebay.
The overload trip is the optional module that fits on the output side of the contactor.
Sized according to the motor.
Another similar device is a safety relay as a E-stop device, I believe it is mandatory in most of Europe and N.America is presently coming on board.
Old 01-01-2010, 10:50 PM
lgalla's Avatar
Thanks Al.
In the case of us home builders are starters necessary?If so is one main starter used or is it just necessary for the spindle.Servo and stepper drives seem to have their own protection built in.Is that enough to meet code.
Have a good beer Al
Larry Edit
Sorry should read Have a good year
Old 01-01-2010, 11:18 PM
Al_The_Man's Avatar
Usually either a contactor ahead of a VFD or a heavy duty relay for a Universal motor spindle is needed.
I usually use one for a E_stop relay or though these are the slightly smaller ones known as control relays, they often resemble contactors, these can cut the power to servo/stepper supplies etc in E-stop.
[IMG] code is Off
Need Help!- Changing Fanuc AC servo driver and motor for a regular VFD and async motor Bordaco Servo Motors and Drives 4 09-08-2011 06:41 PM
Problems with motor stalling due to motor/lead screw alignment Bimmerkc1 DIY-CNC Router Table Machines 3 01-24-2010 07:12 PM
bridgeport cnc Boss 6 retrofit need help wiring spindle starters moriseikimark Bridgeport and Hardinge Mills 1 05-05-2009 03:11 PM
New Machine Build- Mach3 , Config, Motor Tuning problem ( FILM OF MOTOR) MDF_Markazi Mach Software (ArtSoft software) 7 04-30-2009 03:15 AM
To Help us STARTERS ge going!! KustomKoncepts Commercial CNC Wood Routers 17 03-12-2008 06:05 PM
