Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Safety Zone
Safety Zone Discuss safety related issues about machines and materials.
  #13   Ban this user!
Old 11-13-2008, 07:11 PM
mcyr is on a distinguished road
Iman,
I did a little patent searching and found that the phosphine oxide that is used in your material is not cured at visible wavelengths...it still needs UV to cure. Is there something on the bottle that gave you the impression that it could be cured with visible light? Is the preferred source of light for curing mentioned?
Geof,
You're right. I mis-read your post. My apologies.
  #14   Ban this user!
Old 11-14-2008, 03:32 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
Erm.. yes. It's "specificaly designed to cure in the visible wavelengths (above 400nm).
http://www.henkelna.com/cps/rde/xchg...UID=0000000N6B
I got the MSDS on it, but it's like reading hyroglyphics in a mirror after a bottle of JD with one eye closed.
The LD50 and LC50 figures don't seem too low, so I guess it's ok.
Anyway, it's still tacky after an hour on unbonded surfaces so no use to me.
I love deadlines- I like the whooshing sound they make as they fly by.
  #15   Ban this user!
Old 11-14-2008, 06:18 AM
Fe56 is on a distinguished road
LD50 and LC50 figures aren't that important for safety purposes. That's just the amount required to kill half of a test batch of rats, the amount required to kill half of a test batch of humans would be pretty enormous by comparison.
Look for stuff like skin transmission and health effects, and check for terms like 'reproductive hazard', 'mutagen', 'teratogen', 'absorbed through skin', 'carcinogen' and if you see any of those err on the side of paranoia. Latex gloves are cheap, non latex examination gloves only a bit more expensive (doesn't stop my sister the doctor with the latex allergy griping about the cost though) and no amount of money can buy your health back if you've wrecked it by neglecting clean techniques.
  #16   Ban this user!
Old 11-14-2008, 09:08 AM
LOCTITE
® 3556™ cures rapidly when exposed to visible light
of sufficient intensity.
You'll need something like this since the amount of visible light is very poor from halogen bulbs:
http://equipment.loctite.com/product...0Flood%20Units
Also, the technical information mentions that the material that doesn't cure can be easily cleaned with a solvent like acetone.
  #17   Ban this user!
Old 11-14-2008, 10:20 PM
Ditto to what Fe56 writes.
  #18   Ban this user!
Old 11-17-2008, 09:58 AM
ImanCarrot's Avatar
It's not possible to clean the remaining residue off using acetone- I'm making lenses here, it would smear all over the critical surfaces and take as long to clean the stuff off as it would to actualy make the lens. By the time you'd smeared all the stuff all over the lens sod's law states that the thinning layer would cure and become very difficult to remove and the more you tried, the more you'd scratch the lens surface. Oh, and beleive me, I do know about cleaning optics, it's been the bane of my life.
Here! if any you guys want to read about proper optics n stuff then get Frank Twyman's book "Prism and Lens Making" the man was an absolute genius, on a par with Einstein in my opinion. The techniques he used are still used today, sadly by a diminishing few as there's no- one to pass the knowledge on to *sadness*
Oh, erm, the reason I can't have any contamination on my lenses is: the optical system will not work
[IMG] code is Off
Dodgy CMM Paul Goddard Mechanical Calculations/Engineering Design 2 02-27-2007 02:15 AM
Can someone help me with these motor/drives, I think the drives are dodgy? Darc Stepper Motors and Drives 1 07-23-2005 06:31 PM
