Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Safety Zone
Safety Zone Discuss safety related issues about machines and materials.
Old 10-20-2008, 10:28 AM
oakleigh's Avatar
oakleigh is on a distinguished road
only a small fire!
on friday i managed to set fire to the cnc wasteboard (and my work)
i had set the feed rate for 500 mm/pm instead of 5000 mm/pm i was cutting through 12mm ply i realised how slowly i was cutting within 5 seconds of it starting
so i stopped the machine and preceded to change my feed rates by the time i changed it (under 2 minute later!) i had a small fire on my hands. undoubtly caused by my slow feed rate.
i later checked out the tool and found it hadn't been changed for quite a while and was very blunt.
i checked with the main man in the mill he seemed to think that the fire would have started much quicker if the cutter was newer.
i find this hard to believe. i have always assumed if the cutter is blunt it would burn the work quicker therefore if it would start a fire quicker.
does anyone know what is more likely to affect the speed of a fire!?!?!?
Old 10-20-2008, 10:33 AM
Khalid's Avatar
Khalid is on a distinguished road
I was cutting at 80IPM.. All was right..The fire occurred when i put the blower on
Old 10-20-2008, 11:39 AM
oakleigh's Avatar
Cool
thats interesting because our suction bed was on and was feeding the fire as all the air was rushing past it!
Old 10-20-2008, 07:16 PM
Big S is on a distinguished road
Usually you use stir welding on metals I don't think it works to well on wood.
I would say the a blunt bit makes fire faster.
Cool pic though.
Shannon.
Old 10-20-2008, 09:23 PM
keebler303 is on a distinguished road
In both cases the fire was caused by incorrect feeds/feeds and/or by dull cutters, which generate more heat and therefore will start a fire faster.
And it doesn't help to be actively feeding it oxygen with the blower. You have to be real careful about this because your dust collection/vacuum system could suck in a spark and set the whole place on fire.
Keep the fire extinguisher close by.
Matt
Tags
blunt, cutter, feed rate, fire
[IMG] code is Off
What Fire Precautions Do You Use? diarmaid Polls 27 04-12-2010 11:07 AM
Need Help!- Laser won't fire CARTOGATE Laser Engraving & Cutting Machines 3 08-25-2008 03:22 AM
Smoke and fire...yes FIRE! fatal-exception Gecko Drives 13 01-25-2008 02:58 PM
What fire precautions do you have? diarmaid Polls 0 05-20-2006 03:01 PM
