Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Safety Zone
Safety Zone Discuss safety related issues about machines and materials.
Old 03-11-2008, 02:25 AM
yuem is on a distinguished road
Multan cutting fluid
Does anyone have any experience with Multan 97-40 cutting fluid by Henkel?
I encountered some problems with skin irritation.
Did anyone else had that problem?
Old 03-18-2009, 01:57 PM
coolantman's Avatar
coolantman is on a distinguished road
Yuem,
Unfortunately, skin irritation is a common problem when using any type of metalworking fluid. The thing is, different people react differently to different products. You may have problems with your current cutting fluid and then switch to a new one and the issues go away. Another person may have no issues with the first one, but as soon as you change products, the issues show up.
The reason for this are the additives that are in the fluids. Rust inhibitors, biocides, and some emulsifiers are the culprits.
In order to keep ANY coolant issue to a minimun, proper maintenence and bath changing is very important.
Try to stay away from scented lotions, washing your hands with hot water (use warm water), and try to use gloves if you can.
Hope this helps!
-Coolantman
Jonathan Ballard
EnviroServe Chemicals, Inc.
www.EnviroServeChemicals.com
(910) 892-1791
[IMG] code is Off
Cutting fluid for aluminum? Ben General Metal Working Machines 7 11-17-2011 10:03 AM
Disposal of cutting fluid naytep General Business Practices and Pricing 1 10-05-2007 11:34 AM
Cutting fluid sleeper142 Haas Mills 15 07-29-2007 09:05 AM
Window cleaner as cutting fluid voxelman General Metalwork Discussion 12 05-14-2006 02:03 AM
Cutting fluid that doesn't smell? sendkeys General Metal Working Machines 5 09-09-2004 01:29 PM
