| Safety Zone Discuss safety related issues about machines and materials. |
I reciently got into this home machining using machine wax to prototype parts. On Friday evening I thought I would melt down my accumulated wax chips and recycle it. I did that on a stove top using a regular pot my wife donated for the purpose. Later on that evening I started coughing a lot and had difficulty breathing. I don't smoke by the way. Things worsened I became bedridden yesterday afternoon, with major headache, dizzyness and shortness of breath- my temperature was always normal. This morning when I woke up I seem to be fine. I don't know, is this coincidence; maybe symptoms of a new flu bug or should I wear a mask and melt the wax only in well ventillated conditions ? Any input here would greatly be appreciated. |
| Interesting question. According to the material safety data sheet (MSDS) your symptoms do seem to match the effects: http://www.sciencestuff.com/msds/C2200.html
| This is a real strange one! As a kid, I used to chew it for gum. Made about a gazzilion candles. Had my skin covered with it MANY times. Used it to waterproof wiring connections. Seal leaks, hobo cook stove, homemade shaft packing, and a bunch of other stuff. I've NEVER had ANY reaction to it, at all. ??????????? Maybe I'm indestructible, played with lead and mercury all the time as a kid, too. Capt Turk
__________________ Those who would trade freedom, for safety, deserve niether. |
| Machineable wax generally contains a wide variety of materials. Paraffin is usually less than half of the content. They also contain other types of waxes and plastics which increase its strength. I am sure there are also proprietary chemicals added to increase strength, improve surface finish, etc. in most commercial products. There is definately a possiblility of some nasty stuff in them. Carefully watching the temperature can keep the fumes to a minimum, overheating will give off fumes and also become a fire hazard. Definately not the best thing to do in your kitchen. Assuming it is safe is not a good idea when your life is on the line. Most manufacturers probably do not intend for you to remelt the wax, they want you to buy more! so warnings about this might be rare. FYI Legos don't come with any warning either and I'm pretty sure that melting them down in your kitchen would do some damage to your respiratory system as well. I'll never bet my life on someone elses lack of information, I'd suggest others to do the same. If there is a possibility of harm, protect yourself. Be it safety glasses, gloves, lab coat, respirator, parachute, etc. The best way to be safe is to use the safety gear made to kep you safe. Matt |
| The above MSDS is for paraffin, not machinable wax. Here: http://www.freemansupply.com/MSDS/sc...chwax_comp.pdf The ingredients are listed as "proprietary", that enough to scare you? From the MSDS it appears the most damage is caused from inhalation of fumes generated by thermal degradation ie. overheating. Maybe a double boiler type of apparatus would prevent this. In any case, I would still recommend doing so in a well ventilated area suitable for the purpose. Here is there specification for the process: http://www.freemansupply.com/instruction/Reclaiming.pdf found that here: Machinable Wax Matt |
#10
| Hmmm...sounds like I'd buy a cheapie hotplate and do it in the garage with the door open. Or maybe an old electric oven? Or a toaster oven? Again--in the garage with adequate ventilation.
__________________ Greg |
| Safe parameter settings for 730 and 731 | 1ctoolfool | Haas Mills | 0 | 06-16-2007 04:14 PM |
| Is this safe? | foam27 | General Electronics Discussion | 1 | 06-15-2006 07:08 PM |
| Is this safe? | Hack | DIY-CNC Router Table Machines | 3 | 07-27-2005 08:00 PM |
| Mach 2 safe limits ? | qsacracer | Mach Software (ArtSoft software) | 6 | 02-21-2005 01:33 AM |
| Is it safe? | kong | Gecko Drives | 1 | 11-24-2003 10:56 AM |
