Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Safety Zone
Safety Zone Discuss safety related issues about machines and materials.
  #13
Old 05-31-2008, 02:08 PM
*Registered*
Mike Stevenson is on a distinguished road
I think the best thing to use would be a Crock Pot set to a low temp in a completely ventilated area.
  #14   Ban this user!
Old 06-01-2008, 03:26 PM
awerby is on a distinguished road
Wax fumes can do that;
melted wax acts like a solvent does at room temperature, filling the atmosphere with hydrocarbons, which are not good to breathe. You definitely don't want to melt wax in an inadequately ventilated space. Also, it's important to control the temperature precisely. Electrically heated pots are better than melting directly over a stove, but unless your pot has an infinite range control (not just High Medium Low) you're unlikely to get it just right. If it's too low, the wax won't melt, and if it's too high you get a lot of fumes - just before the Towering Inferno kicks in. Really, wax has a flash point; over a certain temperature, it will act like a fuel - think of Sterno on steroids. So if you don't have the ventilation set up, do this outside, with nothing combustible nearby or overhead.
Andrew Werby
www.computersculpture.com
[IMG] code is Off
Safe parameter settings for 730 and 731 1ctoolfool Haas Mills 0 06-16-2007 03:14 PM
Is this safe? foam27 General Electronics Discussion 1 06-15-2006 06:08 PM
Is this safe? Hack DIY-CNC Router Table Machines 3 07-27-2005 07:00 PM
Mach 2 safe limits ? qsacracer Mach Software (ArtSoft software) 6 02-21-2005 12:33 AM
Is it safe? kong Gecko Drives 1 11-24-2003 09:56 AM
