03-25-2007, 07:06 AM
Originally Posted by keithorr Well, I'm glad to have read all this. My cable shield is unattached at both ends, even though the documentation states that one end should be grounded (at the controller end). A back up cable has the ground lead intact, but it was a stock lead from the manufacturer. I started to doubt the setup until I read through the installation notes.
I'm using an open loop stepper system, so I don't have to worry about an encoder feedback suffering from noise.
The thinking at the time by the installer was that noise wasn't going to be as big a risk as a line voltage short.
What was a factor is that I dry mill graphite. The thinking was to keep the machine isolated from the driver box as much as possible, since live (not noise) current might find it's way from the spindle, to the machine, to the cable shield, and back to the controller.
The machine is enclosed, and the enclosure is rife with graphite dust when things are going, to the point sometimes you can't see anything trough the window except a black cloud. There is good exhaust ventilation, but it doesn't always keep up with the amount of conductive airborne particles that end up coating every possible surface and void.
If the cable shield was grounded to the driver box, and the graphite dust made a connection between the shield and the machine, I would have the straight line connection that HuFu mentions in his previous post.
I was told at the time to make sure the machine was grounded well, and keep the driver box as isolated as possible.
I apprecitate that there are standards, but one size may not fit all. If I didn't refer to my vendor notes, I might be tempted to reconnect the shield ground. |
Either you have it isolated or you dont... If you have it 'poorly isolated' then any static will follow that path, waiting to kill whatever it can first. Grounding the frame will keep any voltages from going back to the controller. From the bearings bolting together castings/frame parts, there is always metal on metal contact, so everything should be interconnected, and the bearings should be fine conducing trivial amounts of current from any static. Ideally you would have a ground-steak right next to the machine, the frame would be connected to that, the controller box connected to that, the shelds on all cables would be connectd to the ground in the controller box, but not to the frame to prevent ground loops...
I'd rather have a well grounded machine then a machine isolated as best as I could get, because with enough static, it could arc though to the motor windings, or though insulation on a cable at some point, where a grounded machine would bleed off any charge before it could build. |
