| Safety Zone Discuss safety related issues about machines and materials. |
| LinkBack | Thread Tools | Search this Thread | Display Modes |
#278
| Here's one that happened to me almost 30 years ago back when power tools (saws, angle grinders, etc.) didn't have those safety trigger mechanisms that they have now. In this case it was a 9" angle grinder which back then they all had a switch/trigger which could be locked on. Anyway I grabbed the 9" angle grinder from our tool store, sat it on the ground (disc facing downwards), reached up and plugged it in to the suspended power lead (permanent type, suspended with a light chain) and hey presto... it had been left on (locked on) and therefore went into action (full speed) whilst moving about due to the vibration of the motor, right next to my two feet. I went into "disco dancing" mode trying to avoid the thing and was able to rip the cable out of the lead soon after. I'll never forget that one! |
#279
A double pole relay is one good safety solution and I would suggest a D.P. power relay to switch both hot and neutral. Al.
#280
I am going to have to disagree here. German& Swedish carbide, yes, good stuff. But have you tried Chinese carbide? I have seen carbide cutters rated for HRC32, HRC40, HRC45, HRC50, HRC55 and HRC63. Not quite all the same! I have seen (and have bought) Chinese carbide cutters sold for use on wood, plastic and aluminium. I have checked with the supplier and been told that these are not for use on steel. I have tried using some of these cheap Chinese cutters on steel, just as an experiment, and the corners quickly chipped off. Yes, they are OK on aluminium and plastic. No, they are not OK on steel. I saw a price list for cutters on one web site. As I remember, the site was selling a large range of cutters with pricing roughly as follows for one size: Chinese carbide: $4 Taiwanese carbide: $6 German carbide: $12 Swedish carbide: $16 No, oils ain't oils. Cheers |
#281
Fwiw, I've accidentally cut steel with very high quality woodworking tooling, and it'll chip just about every time.
#283
I found this video in youtube, a boy trying to stop a lathe with bare hands: He was lucky |
| great stuff to work with | trubleshtr | 80/20, TSLOTS and other Aluminum Framing Systems | 24 | 02-06-2009 09:41 PM |
| Great Stuff expanding insulation for lost foam molds? | WayneHill | Moldmaking | 8 | 06-01-2006 05:19 AM |
| You see some interesting stuff on Ebay | DieGuy | General Metal Working Machines | 0 | 05-13-2005 03:40 PM |
| Has anyone tried this stuff (type of delrin) | dmoore764 | DIY-CNC Router Table Machines | 10 | 03-17-2005 09:58 AM |
| welding thick stuff to thin stuff - need advice | cross6 | Welding, Brazing, Soldering, Sealing | 5 | 01-13-2005 01:39 AM |
