Go Back   CNCzone.com-The Largest Machinist Community on the net! > Events, Product Announcements and More > Safety Zone
Safety Zone Discuss safety related issues about machines and materials.
  #37   Ban this user!
Old 11-17-2009, 06:33 PM
mactec54 is on a distinguished road
I have a product that has not really been discovered by many I will be up to speed with it in the next 2 weeks, I have been using it for some months now
The cutting fluid is Biodegradable, Non-Toxic, Fireproof 100% synthetic, This never goes bad in any way & never needs to be changed, You just top up your tank with mix when needed,
Mactec54
  #38   Ban this user!
Old 11-17-2009, 07:11 PM
Originally Posted by .xXACEXx. View Post
......HAS to have BAD STUFF rowing in it which is bad to be around ...so what can kill all the "baddies" and give us good coolant again??
sorry this post is soooo long winded BTW
You cannot kill all the "baddies" but you can limit their growth.
The baddies that make the foul smell are bacteria that live on the sulfur compounds in lube oil in the absence of oxygen; the smell is from sulfide compounds made by these bacteria. They cannot live in the presence of oxygen so the first thing is to make sure the coolant is thoroughly oxygenated. One way is have a tee in the coolant line so that some coolant can be bypassed straight back to the tank through a spray nozzle and run the coolant pump for an hour or so every day. Couple this with getting all the tramp oil out; which is easier said than done because for skimmers to work the coolant has to be very still for several hours and this is contradictory to the aeration using the pump.
My approach was to let the tank sit for several days so I could skim the oil off then periodically aerate it for several days.
However I have to admit that I broke down and bought the expensive solution; an external coolant filter/oil trap which I installed about a month ago. It seems to be working but when I say expensive I mean it; $3600.
  #39   Ban this user!
Old 11-17-2009, 07:30 PM
Geof if you use this new stuff I have been trying out you do not get any bacteria growth, & never have to change it.
You don't need to aerate it ether
what I said in the post above was only a little of what this coolant can do it also eats the tramp oil which is a problem in some machines, the only problem with this is when it is eating the tramp oil it is using it's self up so you have to replenish it with adding more coolant mix
Mactec54
  #40   Ban this user!
Old 11-17-2009, 07:45 PM
Is this the stuff that comes from a company in Canada, near Calgary or Edmonton?
  #41   Ban this user!
Old 11-18-2009, 10:31 AM
Hi Geof you got it, the name of the company is Lube Corp manufacturing & are in Alberta
The product name for the cutting fluid is GreenCut if you want a contact person PM me & I will give it to you, once you have used this you will never go back to any other cutting oil's/fluid's of the past.
For any US sales anybody can contact PM me
Mactec54
  #42   Ban this user!
Old 03-26-2010, 05:19 AM
Pandinus is on a distinguished road
Used to get this problem and found out it was the soap that the company supplied.
Have you ever read the MSDS for Dish Washing Liquid Soaps ??? Nasty stuff... the warnings are not required for home use because "you should only have limited exposure at home."
  #43   Ban this user!
Old 07-05-2010, 06:22 PM
DouglasR's Avatar
DouglasR is on a distinguished road
Some coolants more so than others, but I would think that ANY type of coolant would be harmful if ingested, long term, or high concentration.
One of the CNC's where I used to work had a mist collector on it, because it was processing parts of a type of operation that just made loads of mist. That thing would fill a five gallon bucket at the end of the day!
  #44   Ban this user!
Old 10-15-2010, 10:19 AM
vanm is on a distinguished road
The post I was reading was from 11/09 has anyone had any more experience with this Green Cut fluid. It sounds almost to good to be true. I'm finding that keeping my 8 CNC smelling like roses is becoming more than a full time job. If this stuff really is all it's cracked up to be, i would be interested if giving it a try.
  #45   Ban this user!
Old 10-15-2010, 02:27 PM
vanm
I have been using GreenCut for over a year now, & have only topped it up, there is no smell & I don't aerate at all, I think if you used a filter to take the chips out Etc, you would never have to change or clean the tank out as well, Just keep topping it up
The only thing I have had to watch for is rusting, but I think this is the water i'm using that is causing this problem, GreenCut have an AntiRust to add if you need it
Mactec54
[IMG] code is Off
Water cut?? Yepez CNC Plasma and Waterjet Machines 8 02-24-2010 08:23 AM
plasma water tank snaggletto CNC Plasma and Waterjet Machines 41 06-17-2006 07:04 AM
High pressure low volume water pump DDM DIY-CNC Router Table Machines 28 06-25-2005 02:36 AM
Water Pressure to Cut 1/8" plywood? J Solinger CNC Plasma and Waterjet Machines 0 06-05-2005 08:54 PM
Speed/Torque Boost on Allegro 5804 Based Controller (???) FrankG Stepper Motors and Drives 8 11-28-2004 08:03 AM
