| Safety Zone Discuss safety related issues about machines and materials. |
I found this diagram, mentioned in an old thread, that seems to be a good way to wire up limit, home and E-Stop switches. My question, is if I can just put the E-Stop switch in series with the limit switches and free up a parallel port input? I assume so. Also, should the home switches be in the same location as X--, Y-- and Z++ limit switches or offset from each other? I am using Mach3, if that matters. |
| Hi Race man! NO! Wire the Estop to its own separate input. If you want to save inputs, just wire ALL of the switches NC in one big series loop, connect one end to PSU ground and the other end to one input. Mach3 knows what switch is what. You can use 3 of the switches as both home and limit switches. CR.
__________________ http://crevicereamer.com Too many PMs. Email me to my name plus At A O L dot com. |
OK. Help me understand the reasoning behind that. I know that 3 of the switches can be used as both limit and home switches with Mach3, but I assume that you cannot wire them in series to do so. Seems that I can put the X++, Y++ and Z-- switches in series and tie those to one parallel port input, but leave the combo home/limit switches as separate inputs. |
| Nope! Wire all six Normally Closed switches in series and forget about it. Three of them will also be combo. Mach3 will know which switch is which and for what. CR.
| I'm a noob to Mach3 and CNC in general, so it helps if I have a little more explanation of things for me to understand. I just got my first CNC machine this past week. |
| Mach3 knows where all the switches are. During a cutting operation, if it encounters a switch, it assumes it to be a limit and shuts down. During homing, it first moves the Z until encountering a switch, recognizes home, and backs off a trifle to close the switch. Then it will home the X, and then the Y. Because limits and homes are used in two completely separate operations, it has no trouble doing this. Limit/home/Estop switches use very low Voltages and are easily subject to crosstalk from other wires nearby. You MUST use shielded wire and try to route it not close to other wires. Combining Estop with the homes/limits just multiplies the chances of having spurious signals interupting your CNC program. You may find some of this info to be helpful: http://crevicereamer.com/Page_2.html CR.
| OK, I believe that I understand now. So, I can simplify that diagram and just use two parallel port inputs. One for E-Stop and the other for all of the limit switches in series (3 of those doing double duty as home switches). Can I get the +5V off of one of the other parallel port pins? |
| That is correct about the switches. Regarding the 5v, I believe you want to keep the power on the pc side seperate from the machine sides power. A cheap wall wart will supply the 5v (most cell phone chargers are 5v, check first). You could try the 5v from the PP and if it starts throwing faults get power elsewhere. I have had many problems with grounds and such. Nothing causing any release of the magic smoke but tripping estops and such. In fact it has happened every time I have added something new and electrical in the system, such as probes, relays and limit switches. Good luck and enjoy. Btw when you see it home the first time it is too cool. It works exactly like CR said.
I guess that precludes bundling them with stepper motor wires, even if using shielded wire, correct? |
#10
CR.
#11
| Now, if you want to cut down some of the wiring complexity: I don't USE limit switches with steppers. IMO they are unnecessary. Worst case if you exceed a limit, steppers will just stall harmlessly. Soft limits set in Mach3 work just fine to prevent this though. I consider HOME switches to be mandatory though. CR.
#12
| Do I really even need to worry about an E-Stop? I do have some soft limits set in Mach3, at least for X and Y (until I get the replacement for the Z head that was damaged during shipment). |
| Need Help!- Wiring Saftey Stop and limit Switches | jandalaser | General Electronics Discussion | 1 | 06-12-2010 02:05 PM |
| Wiring Diagram for Generic Breakout board, home and Limit Switches, Generic Drives. | CJL5585 | Open Source CNC Machine Designs | 33 | 02-24-2010 03:39 PM |
| Wiring Home and Limit Switches Efficiently | MrAR15 | Taig Mills & Lathes | 3 | 07-11-2009 12:44 PM |
| Wiring home and limit switches | Hack | General Electronics Discussion | 7 | 01-24-2009 03:47 PM |
| Limit, Home and E Stop Switches | Mr.Chips | General Electronics Discussion | 15 | 01-17-2007 09:02 AM |
